Question about LG Microwave Ovens
Anyone perhaps know why my LG microwave LMV1683ST will not function with a new door assembly?
Sorry for the re-post, but the question I asked earlier was mistakenly marked as Solved. My old door frame was cracked in a couple places but still worked taped together. I bought a new door assembly #ADC73908103, but after installing the new door the microwave will not heat and the carousel does not turn. The light goes off when I close the door, the fan does come on when I press start, and the timer counts down, but as I said the carousel does not turn and nothing is heated. I can put the old cracked door on and it works fine again, but not with the new door. Everything looks identical and I see no reason why it is not working. Am I missing something here? It has to be something simple, but I can't figure it out.
    Master:
  • LG Master
  • 923 Answers
I hate to be the bearer or conduit of bad news, but IF the old (broken) door works, but the new door does not, the new door may not be the exact replacement part! Otherwise, the operation would be identical. Clearly, the problem is not with the microwave circuits because they work fine with the original door! Is there a flexible circuit strip that plugs to or from the door, to the control board in the main unit? If so, does it look any different than the original counterpart to it?
Posted on Apr 18, 2017
  • 2 more comments
  • William Davidson
    William Davidson Apr 19, 2017
    There is no wiring in the door. It should be the exact replacement genuine LG part assembly. It looks identical. Granted, I haven't completely disassembled the doors for comparison, but I have swapped out the plastic latching part that actually latches the door shut. Everything looks identical. Honestly, for someone to help me with this they would probably have to be familiar with LG and this model. It makes no sense. I've read about microwaves being in a "demo" mode, but I don't see how swapping a door assembly would cause that.
  • solver2010 Apr 19, 2017
    Then I think you might be the victim of "cost reductions" by the parts maker. When you look through the glass, are you looking though a screen mesh? Are the hole spacings identical on both doors? The wrong material for the screen, or the wrong hole spacings in that screen will present a different electrical load to the magnetron tube in the microwave!
  • William Davidson
    William Davidson Apr 20, 2017
    The screen mesh in the door looks to be identical in every way. I did however notice a slight difference in the metal frame inside the door. There is a couple of small holes on one side of the new frame that is not on the old frame so they are not exactly identical as I thought, but the difference is minuscule visually. However, if the materials in the metal are not the same maybe that is the problem. I don't know what else it could be. I wasn't aware that the screen in the microwave window was a functional part that impacted the electrical load in the oven. Thank you for that information. Based on that, I think it is probably the materials not being quite right that is causing the problem.
  • solver2010 Apr 20, 2017
    At one time, I was working as a designer on FM radio commercial broadcasting equipment. I had to be extremely careful not end up with "standing waves," which could cause significant reductions in broadcast power and sound clarity. Citizen's Band (CB) radios used to be very sensitive to such "fine tuning" in their heyday! Microwave ovens actually "broadcast" their power into whatever you are cooking ... wirelessly! It all makes perfect sense!
It is not heating up and turn table is not working.
could be a fuse unless the light is on
consider this , a new unit cost half the price of repairs and parts and it could be a magnatron that is shot
Feb 15, 2016 | LG LMV1683ST 1.6 Cu. Ft. Over-The-Range...
I have a Panasonic Microwave NN-A524 and I accidentally knocked the bottom hook off just as I was shutting the door. I can't get it to open now or work in any way but when I switch it on at the wall the...
I laughed my socks off. Without the door hook the door opening or closing mechanism is completely broken. If you have the time you could unplug it and dis-assemble the whole thing from the back and re-assemble it with a new hook, perhaps make a new hook from aluminuim sheet. I would throw it away and but a cheaper microwave.
Dec 14, 2013 | Panasonic Microwave Ovens
I am looking for a door latch part for an Oster OGB81201 microwave oven. Does anyone have any ideas?
model OGB81201; oster microwave, called the service # posted earlier. was told that the model i had is "not serviced by this dept. " only units beginning with OMW####
Aug 29, 2011 | Oster Microwave Ovens
LG Microwave Countertop Microwave Oven LRM2060 ST. The glass on the outside of the microwave door is broken. Can you order just the glass from somewhere and can I fix it myself?
Due to the serious potential for RF leakage, these doors are normally sold as a complete unit assembled by the manufacturer. I could only find the door listed at repairclinic.com for about $80. If you wish to repair yourself, the old door comes off by opening it all the way and lifting straight up at the hinges. The door will then lift off the hinge pins. Reinstall the door new door by aligning it with the hinge pins and allow it to seat straight down. A simple repair.
If you have any questions about this repair, or require addtional assistance, please let me know. I hope this helps you.
Aug 11, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
Broken glass on full sized microwave door
Unfortunately, you would have to replace the complete door assembly, you can find a replacement door assembly for this model at this link:
LG LRM1230W Replacement Part Complete Door Assembly
Jan 07, 2009 | LG LRM1230W Microwave Oven
How do I remove the door from our Sharp R-1874 microwave
Fixed the problem without any help from anyone. If you ask and ask and get no help I guess it is time to take on the problem and see if you can resolve it and I did. NO IT WAS NOT EASY but with a little thought and time over the last 2 days I did get the door changed. Thanks for letting me post even though I got NO help.
Dec 09, 2008 | Sharp R-1874 Convection/Microwave Oven
How to turn off annoying beep sounds of alert and programming
First of all, microwave ovens do not emit ionizing radiation.
The only risk from any leakage is a burn.
Generally, microwave leakage only occurs when the door / door seal is loose or damaged or there has been an improper repair attempt.
You can select a model which lets you turn the beeper on and off by looking for that feature as you shop manufacturer Web sites, or in the store ask the clerk to pull the manual for you to examine, or contact the manufacturer's help center, support center, or FAQ.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. LG / Goldstar owner's manuals can be downloaded here.
If you're interested in other brands, please reply back and let me know. I'll be happy to post contact info.
Sep 26, 2008 | LG LRMM1430 Microwave Oven
Microwave Ovens Logo
70 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
