Question about Garden
I need the model number and horse power of a Kohler engine spec # 4752254 and serial number 1715600891
reynosaelect
  • 165 Answers
SOURCE: Need to find radio code for BMW 740IL
Call BMW agency they can help you with your problem.
Posted on Mar 23, 2009
SOURCE: parts list for Kohler K161T engine
I have a troybilt tiller with a K161T Kohler 7 horsepowe engine. I have replaced all electrical components, spark plug, points, condenser, stater, all wiring, and cleaned magnets, but to no avail. I still have no spark. The points open and close properly, the plug is gapped correctly. Does anyone have an idea?
Posted on Apr 24, 2009
  • 109 Answers
SOURCE: Sears lawn tractor-25 horse Kohler engine-revs won't slow down!
The governor will need to be replaced
  • 153 Answers
SOURCE: electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Posted on Apr 29, 2009
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Posted on Jun 07, 2009
I have a Kohler 12.5 KW marine generator on my houseboat that has a problem I was hoping you could help me with. Specs: Kohler 12.5 KW 79 CID 23HP Mfg date 9-10-96 Gen Engine Serial # 06919 L-29-R
there are some magnets behind the flywheel to cause the battery charging system to recharge the batt. sometimes they come unbonded/loose from the flywheel and cause the engine to become hard to turn. I would start there first.
Apr 03, 2013 | Cars & Trucks
Low water temperature/auxiliary light is flashing why?
Low water temp is because the engine block heater and/or thermostat has failed, or the outlet it is plugged into is dead.
Nov 20, 2012 | Kohler Electrical Supplies
Need wiring sch for7CCKMR61 spec 140291 serial 326977
I can maybe help with that, as this is an old post, if you still need it let me know
Aug 31, 2012 | Kohler Electrical Supplies
Yes i have a dixie chopper i need to order a part in my town but my # has off of my dixie i have the model # x2303 serial # 7069987 i need the model # and the spec# to order my part i have the engine #...
Your machine came with a Generac engine model gtv760 Spec 005058-X
The engine serial number that you provided belongs to a Kohler Model CV23 Spec 75617
Aug 19, 2011 | Dixie Toys
How can I find a parts manual/breakdown for an older Troy Bilt tiller? I beleive it was manufactured in 1987 possible model #870487 definite S/N 87 46 39. This tiller has the 8 HP Kohler engine. I am...
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in horse for your model number and you should be able to find a parts break down for your tiller. If the serial number is 874639 it was made in 3/88 and will be a four speed PTO model.
I find a lot of parts on Ebay for these tillers, your can order parts through MTD but they will be a little pricey. MTD aquired Troy Bilt out of bankruptcy in 2001 and still carries parts for the tillers.
Frank
Jun 27, 2010 | Troy-Bilt Garden
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
Oct 17, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a horse model about 35 years old with a kohler motor 7 horse. What new motor fits. serial no. 360331
In my opinion, (which doesn't count for much, I know) the 7hp Kohler Troy Bilt Horse tiller was the best tiller ever made. Those tillers lasted forever if they were taken care of. I've got one of the 8hp Kohler versions, but it's just not the same.
It's become a lot harder to find an engine to replace these engines. You'll most certainly want to go to a Briggs and Stratton dealer and have them look it up. You need a 3/4" crank, 2 7/8" long with a keyway, tapped for a bolt to hold on the pulley and reverse disc. IF you find an engine to fit, you'll likely need to have a custom throttle cable made up to replace the current one. A good small engine dealer should be able to help you.
Now for the bad news. The 7hp Kohler was a cast iron engine. Any replacement engine you find will likely be an aluminum block with a cast iron sleeve and therefore, much lighter. What this means is the balance of the tiller, from front to back, is going to be thrown off. The result is - it will be MUCH harder to pick up the rear of the tiller when you want to turn at the end of the garden. You will most likely need to either put on one of the bumpers (if you can find one to fit) or figure out a way to hang some weight on the engine. I've seen people do some creative things to get the balance back. Whatever you do, it just won't be the same as that great 7hp Kohler. I'd suggest trying to rebuild it - if possible!
Jun 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Parts list for Kohler K161T engine was mounted on a Troybilt Horse - older model. Need stator number - would like to see parts list or internet site to access it. Kohler has no spark
Apr 05, 2009 | Garden
This is paul at Paul's Outdoor Power Equipment. I have a lincoln ranger 8 with a bad Onan engine. Is there a Kohler spec engine I can usne to replace my engine with.
Hi Paul,
I know that you want a Kohler CH18S but I can't find the spec number you need (Kohler web site won't work with my browser), your Kohler engine deal ought to be able to look this up for you.
Carl
Dec 03, 2008 | Welding Tools
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
