Question about Brother Office Equipment & Supplies
Model mfc5440cn lightweight home use IT is ONLY used for a copying NO fax or phone hooked up. Problem--the led displat read change cyan canister [But not empty]I changed any way NO LUCK!! Cleaned with alcohol/Q-tip NOO LUCK Still locked out NO cyan cannister????
  • dickensinbra Jul 24, 2009
    i'try goor details & i located a auth rep.shop here in brazil
  • 336 Answers
I think there is a problem on the sensor that is reading the cyan ink. Please try below steps, to reset the sensor's thresholds for light and dark conditions.
  1. Power-down the machine with the button on the front panel. Let it finish any cycling.
  2. Unplug AC power.
  3. Lift the right-hand end of the scanner to open the ink cartridge area.
  4. Pull back the white latch hooks to remove all four cartridges. Set the cartridges upright on the table.
  5. Brother says aftermarket ink cartridges may cause this problem. Make sure that all four cartridges are genuine Brother ink. Replace any generic ones before going farther.
  6. Check the levels of the ink visible in the cartridges. The machine has sensors that look through the clear rib in the right-hand side of each cartridge. Assuming you find all cartridges at least half-full:
  7. Leaving the machine open and empty of ink, plug in the power.
  8. The display will tell you it has no black ink, and to install a cartridge. Install the black ink.
  9. Following the color order on the display, reinstall each of the ink cartridges.
  10. Lower the scanner. You'll have to push in the top end of the blue support bar to start lowering it.
  11. The machine should come up ready.
If the routine above doesn't help, try cleaning the sensors, easily visible and accessible when the ink is out. Poke a pipe cleaner down into the sensor gap and twirl it a bit to brush out dust.
If this still won't work, resetting the memory in Maintenance Mode might help:
  1. In rapid succession, touch Menu, Black-Start, ^, ^, ^, ^. (That's the up-arrow button, four times.)
  2. If you were successful the display should read MAINTENANCE, and all lights should flash together. If not, touch STOP and try it again.
  3. Touch 9, 1. The display should read PARAM INIT for a few seconds, while it erases most of its memory. It will not clear its programmed name and phone number, nor the fax directory entries.
  4. Touch 9, 9 to exit Maintenance Mode. The machine will go through its complete power-up sequence, taking about a minute to reach its Ready condition.
  5. A more desperate step would be to repeat this sequence, except instead of touching 9,1 touch 0,1. This will clear ALL memory, including all programmed names and phone numbers, bringing it back to new, out-of-the-box condition.
If you still have the problem, you may have a bad ink sensor board -- leaking ink sometimes contaminates the board -- or the board may be off its mounts. I suggest you bring your unit to service center and have your sensor checjed/diagnosed.
Regards,
Jeep Brainy
Posted on Jul 24, 2009
Oki c5550 INCOMPATIBLE YELLOW
Are you using factory or aftermarket toner?
Jan 07, 2014 | Oki Electric Industry Okidata C5550n MFP...
Is there a Fax modem available to be connected with scanner, copier and printer (three in one already with us.)
your unit has a fax installed in the unit.
Look at page 29 in your manual it will show how to send and receive a fax.
send a fax page 29
receive a fax page 32
print reports page 33
feature purpose
1 Phone Hook: the green LED in the shape of a phone indicates that the fax
line is in use when lit.
2 One-Touch Speed-Dial Buttons: use to access the first 6 speed-dial entries.
3 Auto Answer: when the green light is on, fax transmissions will
automatically be accepted.
4 Speed Dial: use to access speed-dial numbers that have been set up from
the front panel or with the HP Director software.
5 Redial/Pause: redials the most recently dialed number when in the ready
state. Inserts a pause (hyphen) when in the dialing state.
6 Keypad: use to dial fax numbers, and enter numbers such as the quantity
of copies or percentages when reducing or enlarging. You can also enter
text using the keypad for fax header, use speed dial entries, and specify
menu items.
7 Fax Resolution: use to set the fax resolution to Fine, Standard, 300 dpi,
or Photo. It will remain at the most recent setting until changed.
8 Start Fax - Black: starts a black and white fax.
9 Start Fax - Color: starts a color fax
Apr 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How to set fax machine part to received faxes when not at home on the # mfc5440cn.
2 Press Menu/Set, 2, 1, 3.
3 Use ▲ or ▼ to select On (or Off).
Press Menu/Set.
4 Press Stop/Exit.
Oct 08, 2009 | Brother MFC-5440CN All-In-One InkJet...
Brotherintellifax4100...will not copy, send or receive fax
This might work: Press Menu, Mode, 0 to enter the Maintenance Mode. Then touch 91 to clear most of the machine's memory. (But not your phone numbers & stuff.)
More likely, that won't work, because your keyboard is messed up. These machines won't allow you to press a key when another is still down. Is one key sitting lower than the others? Or maybe water has been spilled in the keyboard? The keyboard itself might be bad. I've had to replace one only once, but it happens.
May 13, 2009 | Brother IntelliFAX 4100 Laser Fax
Copy machine won't copy
you will probably have to have all cartridges working.
Aug 04, 2008 | Brother MFC-8220 Fax
Will not fax
It is a default message when you are calling from the same phone as your fax machine.
If yourAll-In-One is sharing a phone line with your telephone, modem, or another device, and if any of the other devices is using the line, you will see the "Phone off hook" message on the All-In-One front panel. You can still print, copy, and scan with the All-In-One when you see this message, but you cannot send or receive faxes. To clear the message, check each device to make sure that it is no longer using the line.
Apr 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
Brother intelliFax 1860c
1-use alkhol with little piece of clean old clothes to clean both connection points in both cartridge and fax.in the place where you put the cartridge.
Mar 02, 2008 | Office Equipment & Supplies
Cannot receive faxes or do copies
If you still have your old cartridge reinstall it that will tell you if it is the cartridge or not. If you still have the problem,it could be the encoder.
Oct 23, 2007 | Office Equipment & Supplies
Conon Super G3 Copy Fax Scan
I`m trying to scan a multi paged document into my dell inspiron 1521 laptop , however when I scan the doc it will only scan into images not into microsoft word where I want to make changes before e-mailing the doc.-----I lost the original in microsoft when the old comp.crashed. Any suggestions would be appreciated.
Oct 05, 2007 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
24 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
