Question about Vision Televison & Video
My DVR will not record your show and cable vision knows about it since Nov. of last year and still has not fixed the problem. Do you know how to fix this problem?
    Top Expert:
  • Vision Master
  • 80,378 Answers
This is the wrong website.
Posted on Apr 18, 2017
How do i hook-up my vcr to my cable dvr to record saved shows
In order to record from VCR to DVR You need to connect "VCR audio/video output RCA jacks " to" DVR 's Audio / Video Input RCA jacks.. ..
use either "RCA analog (red/white+ yellow ) " or "optic " cable.(any standard optical cable )..if exist .optic is the best way to connect it..Remember your VCR 's "OUT" goes into" IN "of DVR ..
pls also remember,wherever you connect your VCR on your DVR ,you should switch the source selector accordingly to correspond to the connection on the back...
Now you can record anything on DVR which played in VCR ..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Motorola Televison & Video
Since my comcast switched to digital I cant record !! Is this DVR compatiable with Comcast digital cable???
Yes,all DVR compatible with digital signal that included Comcast digital cable.U can't record because probally the program u tried to record it copy write protected.What did u tried to record?Just tried to record some plain show,If it is recordable than u know the deal.
Feb 02, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Skipping, feezing on recorded programs. third dvr. all same
I am very sorry to hear you have continually experienced problems with your VIP 612 DVR receiver, a important question when considering what may be causing issues with the numerous receiver you have had is, are you fully powering off the receiver each & every night? If not I would recommend doing so, by powering off the receiver each night it allows the receiver to receive necessary updates and helps to prevent these types of DVR issues. Perhaps you may want to try this and seeing if it resolves the problem. Additionally, another recommendation I would like to make to hopefully help prevent further frustrations with the DISH Network DVR receiver, would be to delete older recordings you have already watched or may not need anymore, this can also help when trying to prevent & fix DVR problems.
I hope these tips resolve the issue or help to improve the DVR functioning. Please let us know if you need any further assistance.
-Kirstie DISH Network
Apr 09, 2010 | DISH Network ViP 612
Want to copy shows recorded to DVR onto computer Howto...
ArmyMason,
Unfortunately as a Dish Network Employee I must inform you that acording to Dish that is not possible however a good computer tech may be able to help you with a work around but keep in mind that if any damage occurs to the receiver that Dish will charge you for the receiver. When you do upgrade check into the receiver models that have an expansion port for an external hard drive. A 211 which is a solo hidefinition receiver without DVR can have a port activated for as one time charge of 39.99 and you can use the hard drive you supply as the DVR. Yoiu also will not be accessed the 5.98 DVR fee every month and if the receiver needs replacing you still have your recordings. Thanks for using Fix Ya.
Apr 01, 2009 | DISH Network DVR 510 DTV Receiver /...
Recording on my Dish 625 dvr
Okay, we can do this. Go to the menu on the satellite at either TV locations. and press 8 then 5. You are now at the Record Plus screen. Move the highlight to the record preferenceand toggle up or down to the desired record preference.After this ensure that you select enable on the activation side of the screen. You will then need to select done. Now you are in business! Thanks ffor using Fix Ya.
Mar 23, 2009 | DISH Network DVR-625 DTV Receiver /...
Dish Network DVR 625 Problem with playback of recorded shows
It sounds as though the hard drive is about to go south on you soon and the receiver is going to need to be replaced however, in the interim you can change the options of the recordings and make it a default so that the recording continues past the end of the show. It is possible that extending this time will allow you to view the portion you want before it skips to the end. In order to do this press the guide button and select a program in the future. On the create timer screen select the option icon. You will now be at the timer options screen you can extend the time the recording will last after the end of the show and when it will begin recording prior to the show. I would also set this as your systems default so that it performs the same way regardless of what you are recording. According to the latest known receiver issues this is not identified as it is a common indication that the hard drive has an error internally. If this works I suggest that you have a replacement sent to you so that you do not lose the use of your DVR un-expectantly.Remember to watch all recorded events prior to replacement as you will lose that info when the receiver is swapped. Thanks for using Fix Ya.
Mar 09, 2009 | DISH Network DVR-625 DTV Receiver /...
Connection to TV by HDMI cable
The 625 is not a high definition receiver and therefore does not support hdmi. You can use RGB or S-video to provide a higher quality picture than the coax output. If you need more options let me know. Thanks for using Fix Ya.
Mar 06, 2009 | DISH Network DVR-625 DTV Receiver /...
When watching DVR recordings, the playback freezes
One of two things may be occurring. The first is a Line Of Sight issue may have been created if you have a limited LOS by wind moving foliage interrupting the signal. This will usually be preceded by pixelization or blocking appearing on the screen. The other instance is the hard drive in the receiver is faulty and in need of replacement. I will almost certainly assure you it is the latter of the two. You can upgrade the receiver to gain the ability to use an external hard drive to download your recordings so that the next time you need a receiver replaced you won't lose your recordings. The other benfit is that if you get a receiver tht does not have a DVR but is able to use an external hard drive you will save the cost of the DVR fee each month which in a year will save you thirty one dollars as there is a 39.99 one time charge to turn this capability on. In the first year alone you will have recouped almost the entire cost of the one time fee and in the second year will have probably recouped the cost of the external hardrive also.
Thanks for using Fix Ya. If you need further assistance please let me know.
Jan 06, 2009 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR 625 Schematic
Scott Dish internal receiver schematics are proprietary information and is not available to the public this includes DVR's as well. If you need cabling assistance let me know and I can assist you. Thanks for using Fix Ya and let me know if I can further serve you.
Dec 28, 2008 | DISH Network DVR-625 DTV Receiver /...
Toshiba D-R410KU DVD recorder, How do I set it up with a regular TV and no cable box? I want to record regular TV shows and I receive only local station via Rabbit ears .
No offense intended, but...get a life and a new TV and a cable box with DVR...pre-record your shows and later record on Toshiba DVD recorder using HDMI cable, available at Fry's for $10. Also, you might still be able to do what you want if you are willing to read every word of every page of the user manual...been there done that...it wouldn't work for me either until I did same...I know, only read the user manual as a last resort, so...
Oct 08, 2008 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Vision Televison & Video Experts
D. E. Hev
shaun taylor
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
