Question about Miller Welding Tools
Owner's manual for a Miller Thunderbolt 225 A.C. ARC Serial No. CK 33732
    Habit-Forming:
  • 27 Answers
Posted on Dec 28, 2017
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Posted on May 08, 2009
  • 225 Answers
SOURCE: ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Posted on Aug 02, 2009
  • 71 Answers
SOURCE: arcing before pulling the trigger
does this unit have a high side and a low side if it does plug it into the low side and try it.
Posted on Aug 08, 2009
  • 87 Answers
SOURCE: does the fan run constant on older miller
Yes, it should run whenever the unit is running
Posted on Oct 30, 2009
  • 5603 Answers
SOURCE: I have a miller thunderbolt 225v AC arc welder
The blank should be the grouDING conductor (green) and they may have a green screw to further indicate it.
Since the welder runs on 220, either of the hot wires can go to either of the other terminals (X or Y).. Those wires might be black, red, blue, brown.
There is a slight chance it would be white even though it is hot on the portable cord because some portable cord is used that way.
VERIFY the receptacle you connect to is wired correctely before connecting your unit to it.
Posted on Jan 24, 2010
Miller 200Le arc welder something fell against the starter and it shorted the motor out now it shows power to evrything . but will not even turn over
Here is the manual for a miller machine. It may be close but it really depends on the serial number. Troubleshooting starts on page 22. There is a schematic on page 26. Check at the lower left for starter circuitry. https://www.millerwelds.com/files/owners-manuals/O411P_MIL.pdf
Nov 05, 2017 | Miller Welding Tools
Tip
Sharpening electrodes when tig welding in DC
Use the smallest tungsten possible, ie 1/16" welds up to 115amps. Hold the tungsten straight up the face of the grinding wheel so the striations go up the tungsten. This encourages the arc to go straight down the electrode thus avoiding arc wonder on lower amperages. It also helps to make the point as long as possible to encourage a finer arc. Happy welding.
on Feb 06, 2012 | Bobcat Miller 225 Welder Generator 907209...
Serial number miller AEAD 200LE JF 885778
Check this out:
http://www.ebay.com/itm/MILLER-AEAD-200LE-CONSTANT-CURRENT-AC-DC-ARC-WELDING-GENERATOR-GAS-POWERED-/310368057796?pt=BI_Welders&hash=item484360b9c4
Jan 13, 2012 | Miller Welding Tools
Jan 24, 2010 | Miller THUNDERBOLT XL 225 AC 230V 50/60 HZ...
Changing from 480v 3 phase to 220v single phase need diagram on a Miller Dynasty DX tig welder Serial # KH577649 stock 903519-01-1
i have a old miller thunderbolt CC*AC/DC welder its wire single phase 480 can it be switched to 220 single phase
Dec 02, 2009 | Miller Welding Tools
Does the fan run constant on older miller thunderbolt 225
Oct 30, 2009 | Miller Welding Tools
225 thunderball,has no plug cord,need to know where to hook incoming cord inside welder
The following link will provide you with information about a 225 thunderbolt. We have serviced many Miller welders over the years and find them to be very reliable. Good luck with your project.
http://www.millerwelds.com/om/o316g_mil.pdf
Jun 20, 2009 | Miller Welding Tools
Arcing before pulling the trigger
May 27, 2009 | Miller Welding Tools
Welding Tools Logo
277 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
