Question about The Video Game Consoles & Games
How do i fix my seatbelt. its locked in the shut position
-it got stuck because someone stuck it in the wrong consol
  • The Master
  • 3,178 Answers
Have someone hold the release button down and pry the belt buckle out with some screwdriver or something.
Watch out lest someone gets hurt when the screwdriver slips.
God bless your efforts.
Posted on Apr 18, 2017
My 2016 nissan sentra middle rear seat belt is stuck in the retracted position. I can't use the seatbelt. how do I get it to release?
The likely cause is a broken spring/mechanism in the belt coil. I'm sure you can get a replacement for this belt.
May 22, 2017 | Nissan Cars & Trucks
Stuck seatbelt locking mechanism in back seat of Nissan Tida
I strongly suggest replace if driving children if jamming
May 11, 2014 | Baby Gear
The back left seat seems to be stuck due to the locking of the middle seatbelt. Any idea on how to fix that?
When a seatbelt locks up it is usually due to dirt or corrosion in the automatic locking mechanism. The mechanism can't release because it is under tension. If you get into the cover that houses the release mechanism for the seatbelt, you may be able to hit it with a little wd-40. You do have to release that tension so that the lock will spring back to the open position and allow the seatbelt to retract. Try the lube. Sometimes the galvanized coating on the internal parts causes a seize.
Apr 07, 2014 | Jeep Grand Cherokee Cars & Trucks
Driver seatbelt stuck
Try squirting some type of penetrating oil down where the belt inserts into the lock, then while pushing the release button as hard as you can, wiggle the belt latch up and down as hard as you can. Personally, I like SiliKroil penetrating fluid.
Aug 23, 2012 | 1997 Toyota Corolla
Maytag Neptune washer shutting off in mid cycle
It must be the timer that is causing the control board or "computer", as you call it, to shut the cycle down, especially when the machine shuts off at almost exactly the same point in the cycle. The control board energizes the timer motor and monitors changes in the timer inputs. It will open the power supply line relay and shut off the machine if the timer inputs do not change within 5 minutes of continuously energizing the timer motor. It means the timer motor is stuck or the timer internal cam is broken at the point where the machine shuts off. Replace the timer (part #22002867) to fix the problem.
Disconnect power to the washer and remove the three screws securing the console's rear cover plate across the console's rear top edge.
The console has six locking feet that secure it to the top cover. Gently rock the top of the console forward then push the bottom of the console toward the back of the machine to release the locking feet from the slots on the top cover. Once the locking feet are released, remove the timer knob by pulling it off the console; lift the console then flip it forward onto the top cover to access the timer.
Disconnect the timer wiring harness then remove the timer mounting screw.
Lift the timer locking tab near the end cap and slide the timer toward the end cap to release the timer retaining tabs from the slots in the console. Lift the timer off the console then install the new timer.
Align the three tabs of the timer with the slots on the console then insert the tabs into the slots.
Lift the locking tab slightly then slide the timer back into position until the locking tab can engage with the slot provided in the console. Secure the timer with the mounting screw then reconnect the wiring harness.
Reinstall the console by lining up its six locking feet with the slots on the top cover. Insert the locking feet into the slots then rock back the console into position. Secure the console's rear cover plate across the console's rear top edge with three securing screws.
Mar 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Rear seatbelt stuck in retracted position
the only thing you can do because of design is replacement. it is designed to lock with forward momentum and if its stuck now, it will do it again. happy holidays
Dec 24, 2009 | 1995 Oldsmobile Ninety Eight
Automatic seatbelt 1994 saturn
You may have to replace the seatbelt positioner.
Check with Saturn (or their replacement GM division) to find if the warranty is extended for seatbelts (some manufacturers cover seatbelts forever) 800-553-6000
Jul 13, 2009 | 1994 Saturn Sl
Saturn sc 2 seatbelt fuse
The fuse is in the center console, left side of passenger footwell. It is labelled PREST. for passive restraints. Possibly check the restraint module located in the center console, just under the E-brake lever.
Jul 02, 2008 | 1992 Saturn SC
Video Game Consoles & Games Logo
27 people viewed this question
Top The Video Game Consoles & Games Experts
Connie Brassard
Connie Brassard
Are you a The Video Game Console and Game Expert? Answer questions, earn points and help others
