ArcticAire Model#AAC5044DE- - in use for several years and works very well- - however, I note that there is no water discharged, and never has been- - is this a concern?
  • 867 Answers
No, it just means you live in a nice non humid area. if its cooling, all is fine. it does not have to condensate.
Posted on Jul 24, 2009
Does anyone know how much it costs to fix a samsung dishwasher that shows e3 code? Is it a big fault or simple fix?
you may have a problem on the draining system. Previous cycle not fully drained and holding off the new cycle.
remove the drain line from its discharge position and hook up a 5 gal container for it to drain in ( maintaining the necessary height for the anti syphon loop )
Select programme 7 which should allow the drain pump to kick in straight away
You should be able to hear the pump running at the bottom of the machine and observe a discharge from the hose.
The chances are the pump needs removing and cleaning.
or - the drain line where the machine discharges is backing up and not allowing a free discharge.
Jun 11, 2016 | Samsung Dishwashers
Where can I find the owner's manual for an ArcticAire dehumidifier model ADR30A2G?
The ArcticAire ADR30A2G is made by Danby and the instruction manual is on the product page here: http://www.danby.com/en/US/our_products/dehumidifiers/adr30a2g . Click on the Specifications tab and look at the right hand column near the middle of the page. The direct link to the manual is http://www.danby.com/cms/documents/pdfs/en/ADR30A2G_20140410_web.pdf .
I hope this helps.
Oct 12, 2014 | Dehumidifiers
Am interested in purchasing a Magtag washer Model #MHWE200Z. space is severly limited. Stable, closet installation. Plumbing limitations require an ELEVATED washer discharge height of some 36 - 4-...
Hi and welcome to FixYa, I am Kelly. Cutting to the point here, I will tell you that this is a problem just waiting to happen. Even if you could get it to pump the water that distance you going to have longer than normal drain cycles and will get Suds or drain out errors repeatedly. As a good rule of thumb... if the drain has to be higher than the cabinet your asking for problems. The manual can be found here:
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10295008.pdf
Make sure to read the warnings and notes in the manual above.
Thanks for choosing FixYa,
Kelly
May 16, 2011 | Maytag Washing Machines
May tsurumi submersible pump is overheating.do i need to oil on the plug of the of the pump? Is it ok if increase the discharge diameter? What will be effect of it? Hope u could enligthen me on this...
This is a single phase induction motor. You mentioned it is overheating. You did not mention whether or not you had easily turned the pump by hand. Pumps overheat for several reasons but these are the top 4:
1. The head pressure is too high as in the pump is being used to pump water higher than the head level of the pump. (Lift distance to high)
2. Low utility or generator voltage. Lower than the pump rated input power requirements.
3. Bearing Friction or motor / bearing mis-alignment ( 3. Pump is sitting in debris while pumping and the pump inlet is being blocked by debris. Also... if it sat in clay and the clay dried inside the pump it can restrict water passages to the point that the pump just can not pump enough water to stay cool.
Does it overheat when pumping at 15 feet or less? I note that this is actually a 1/2 Hp pump. The max LIFT distance for most 1/2 Hp Pumps is 23 feet or less using a 1 1/2 in discharge. The lift will be even less with a 2 inch discharge outlet. As for oiling the pump... Most submersibles always have oil above the impeller and it usually does NOT leak out unless the seal between the impeller and the motor stator / aramture has failed letting water into the winding. That plug you mentioned is for checking to see if water is in the winding area. If you pull the plug and get water the seal is bad. Hopefully you can save the winding.
You asked what the effect would be if you went to a larger discharge diameter. This will give you more volume but less head / lift distance.
Thanks for choosing FixYa.
Kelly
Apr 06, 2011 | Tsurumi Pump s Submersible Water Pump ...
I have an arcticaire a40ra model which usually holds temp at 4C. I came into work this morning and everything is frozen. I don't see a thermostat to adjust or reset temp. How do i adjust the temp?
There has to be a control somewhere on the fridge. Some newer models have digital controls located on the outer doors panels, or its going to be inside. Read your owners manual
www.FixMyFridge.net
Mar 08, 2010 | Refrigerators
It will cool for a bit then switch to fan which blows hot air (from outside most likely) then goes back to cool air for a bit....never happened in past 3 years i've had the unit & there is no water...
If it has an energy efficient installed and turned on; it will do just that. If it does not, then, it is possible that the unit needs to be turned off until the tubing defreezes and it may be a possible solution...if not, then ...call a repairman. God Bless, ac
Jun 26, 2009 | Ocean Aire ArcticAire 6012 Air Conditioner
Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Red light wont shut off
check to make sure your fill bucket is correctly placed back into the unit. there is a safely switch that will not let the unit work without the bucket in place..hope this helps let me know?
Aug 24, 2007 | Danby DPAC10031 Air Conditioner
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
