Question about Haier Televison & Video
Haier model 15HL25S when I turn the power on the green light flashes and the screen flickers one and goes off and then the red standby light comes on
When I turn the power on the green light flashes 5 times and the screen flickers once and goes off and then the red standby light comes on
SOURCE: Does not turn on.
i had my power supply blow on mine within the first year took it in because i had extended warranty and they fixed it, only problem was finding a dealer in my area to fix it, then took over a week, because of customer support issues
Posted on Nov 04, 2007
davebies
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
mistersony
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
  • 4234 Answers
SOURCE: SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Posted on Mar 19, 2009
ginko
  • 19396 Answers
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Jan 25, 2013 | Emerson Lc320em1f TV
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
May 14, 2010 | Haier HLH406BB 40 in. LCD HDTV
TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Televison & Video
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
When switching the tv on onlypower/standby red light comes on not
How many blinks when its red ?
The blinking is a code from the microprocessor telling why it's not turning on.
Apr 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Flm-3201
my polaroid model #3200  does'nt come on!  the light goes from red to blue and nothing,the picture stays black with no flashing or flickering
Apr 01, 2008 | Polaroid FLM-3201 Television
Televison & Video Logo
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
