Question about Sears Garden
Sears tractor won't start. Engine won't turn over.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Most likely battery is flat, Then dirty connections, then failed ignition switch, then failed starter motor.
So charge or replace battery, check and clean all connections, check switch operation with the ohmeter setting of a multimeter, then replace starter motor, then replace tractor (not seriously).
Posted on Apr 18, 2017
Sears mower won't start
Your question,doesn't say if the tractor won't start or the tractor won't crank over. Need to know which is it? There could be two answer to two different questions here. Need to be more precise of the problem. Sincerely,Brad Locke
Feb 24, 2013 | Sears Garden
Won't turn over easily.
how new is the battery have it load tested to see.
Aug 23, 2012 | Garden
My 1976 sears 18 hsp riding mower quit running now it just cranks but won't fire it has a onan engine
check for spark then spray a little carb cleaner or starting fluid in the carb if it fires its a fuel problem filter pump carb
Apr 10, 2012 | Craftsman Garden
Sears GT 5000 garden tractor with Kohler 26 HP Courage engine. It won't start when it gets hot. It turns over, and sometimes just barely runs for a few seconds, but then dies. Choking it a little...
check spark plug sounds it s heating up to much make sure of oil level and if it has been sitting a while dump the gas in it and fill it with new and buy some sea foam and add a little to the gas
Jul 19, 2017 | Craftsman GT 5000 26 HP54" Garden Tractor...
My name is jim. My Sears Craftsman lawn Tractor
Clean the carburetor. The needle and float are stuck closed, passage blocked or a jet plugged with debris. Give it a good cleaning.
Jul 30, 2011 | Craftsman Garden
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
26 people viewed this question
Top Sears Garden Experts
Tim Whalen
John M Grubb Sr
Matt Olenzek
Matt Olenzek
Are you a Sears Garden Expert? Answer questions, earn points and help others
