Question about NordicTrack Exercise & Fitness
I have a nordictrack t7.0 when I'm walking at 4.7 all of a sudden it escalates to 9.9 running mode ,which is much to fast for me
2 Suggested Answers
  • 13 Answers
SOURCE: walking belt on NordicTrack C1900 is to loose, how
Tighten the rear roller bolts evenly with the unit off. The correct tension is when you firmly lift up on the right and left edges in the middle of the walking belt and get 2-3 inches gap above the walking board. If one side is looser than the other, the walking belt may wander sideways. Turn the rear roller screw on the side that it shifted to in a clockwise manner(1/2 turn at a time). Test on a low speed and adjust as needed. (you may manually recenter the walking belt with your foot if it shifted too far to one side and is rubbing on the plastic edges.) You likely have a worn motor belt that needs changing or even a pulley on the front roller that is slipping and needs replacing. They all cause slippage.
Posted on Oct 03, 2010
I have a nordictrack a2350. The belt runs fine until you step on it. How do I fix this?
the walking belt may be loose. adjustment screws are at the back of the walking belt. one on either side
Mar 30, 2015 | NordicTrack Exercise & Fitness
How do I fix a NordicTrack C2050 treadmill that has abruptly stopped?
see if you can remove the motor hood and look at the drive belt. it is a little belt from the motor to the front pulley to turn the walking belt. its either broke or fell off
Oct 21, 2014 | Nordic Track Nordictrack C2050 Treadmill...
Belt stops when stepped on
sounds like the belt is loose.there are bolts at the back on either side that tighten or loosen the belt.adjust with belt running about 3mph. tighten both bolts about 1/4 turn each while watching the belt to make sure it is centered. give it about 15 seconds after you tighten to see the adjustment that u make.the walking belt should only be able to lift up a little bit like 1 inch. you shouldn't be able to get ur hand all the way under belt (not running of course).
Apr 09, 2014 | Nordic Track NordicTrack A2750 Pro...
My NordicTrack T5zi Walking Belt Treadmill won't
Very likely your console went out. I usually check for voltage running to the console (the wires in the back) and if it has juice but will not come on, I replace the console. As far as "why", usually it is power fluctuations, it can be as simple as turning on a high-amperage piece of equipment, or running too many electronics on the same circuit. I see consoles go out from low voltage more often than high voltage.
Nordictrack is an Icon product, you can download the product manual and parts diagrams at iconservice.com.
Feb 02, 2013 | Exercise & Fitness
7600R will not decline below 4 and cooling fans wont come on
RUN THE SOFTWARE CALIBRATION FOR EASY DIAGNOSTIC, TROUBLESHOOTING AND FIX IT
GOD BLESS YOU
Sep 27, 2012 | Nordic Track Nordictrack 7600r Treadmill...
My nordic track apex 6100 xi all of the sudden won't run...or walk...at all? HELP!
Dear Sir:
This is probably a 1) faulty speed sensor or 2) the speed sensor is not plugged in properly. Its also possibly a 3)faulty motor control board or lower board.4)the drive motor is faulty 5) The drive belt is broken.6) Resent c.breaker 7) Test the power cord. 8) Reset the c. breaker from your home. 9) Do not use extension cord .
Adjust the speed sensor see the diagram, and RUN your software calibration for easy diagnose and troubleshooting. read your user manual.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 11, 2012 | Nordic Track NordicTrack Elite zi...
How to adjust the running belt??
Check page 27 in the owner's manual:
"If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD. Using
the allen wrench, turn both rear roller bolts clockwise,
1/4 of a turn. When the walking belt is correctly tightened,
you should be able to lift each side of the walking
belt 3 to 4 inches off the walking platform. Be
careful to keep the walking belt centered. Plug in the
power cord, insert the key, and carefully walk on the
treadmill for a few minutes. Repeat until the walking
belt is properly tightened."
Dec 18, 2010 | Nordic Track NordicTrack Treadmill, A2550
Walking belt on NordicTrack C1900 is to loose, how do I tighten it? When walking on it when u get to level 4 it just about throws u
Sep 30, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a NordicTrack EXP1000. The walking belt was so far to the left that the edge began to fray. So, I adjusted the belt towards the right and now it slips forward now and then when it gets up to 3mph or...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
If their is still slippage then the drive belt will need to be adjusted.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Find the set bolt(s) on the motor.
This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt but do not remove.
The drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described above. Tighten the bolt and test. If the problem is not corrected, if problem persist replace drive belt
Jun 11, 2010 | Nordic Track Nordictrack Exp1000 Treadmill...
Nordictrack EXP1000i stopped in the middle of program
Your drive motor is over heating. Usually caused by friction from the walk belt. The belt needs to be lubricated. (silicone only) Loosen the adjusting screws on the rear of the macine ten revolutions lift up the belt and using a spray silicone lubricant (from any big retailer) spray a light film on the deck (walk board). Retighten the adjusting bolts ten revolutions. If this does not help I would suggest replacing the walk belt. Good Luck, Tim
Nov 11, 2009 | Exercise & Fitness
Exercise & Fitness Logo
29 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
