Question about Boating
Finding out what year motor is serial 09755920
Year of serial #0D122790 mercury motor 2.5
You'll find a tag on your bracket.
The upper numbers you'll find your serial number,
Then in the 'box' just below the 4 digits indicating the production year.
Is it a 2.5Hp, or 2.5liter? Your serial is in the V-6 2-stroke 135-175 Xr range...
Sep 21, 2017 | Mercury Boating
I need to know the specs on an evinrude outboard motor serial # 3030-07926
Everything in marine outboard engines is tied to MAKE and Horsepower. From that, you can find the year using the serial number. Once you have those, you can Google
year make model specs
or
year make model manual
Evinrude Outboard Motor Model Numbers
Jul 30, 2017 | Boating
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
Finding year from a ssrial number on a mercury out bord
go google and type in--- mercury outboard serial numbers -- there are sites that listhp against serial numbers against year of manufacture
while you serial number may not be listed they state that the beginning of the number to the next changing number is the year of make
for example ---4261012 to 4302999 ( next number 48103665,year 2002) may be year 1999 so your number would be a 1999 model
The information provided will take a bit of understanding as it appears that the manufacturer changed the method a number of times
talk with a mercury / mariner service shop as they will have the information on hand
Sep 26, 2016 | Sierra Tilt/trim Motors, Outboard...
Find the manufacture year mercury verado motor
According to i-Boats, "Nothing in the Mercury Mariner Outboard engine model numbers or serial numbers provides year information directly.
The first serial number sold in a year becomes the beginning serial number. Serial numbers between that year's beginning serial number and the next fall into the same year. Search for your engine horsepower on the Mercury Mariner serial number year chart located here to find the beginning serial number for the range that includes your engine." Your other option is to take the serial number to an authorized Merc marine eager and they can look it up for you.
Sep 27, 2014 | Boating
What year is this motor
Model 0D-21 Serial 7G454DG What year is this. We believe around 1960 or so but are having trouble finding parts without exact year.
Jan 06, 2014 | Boating
Mercury outboard s/n 9445826, what year was this motor built ?
call mercury outboard they can tell you the answer to your question
Aug 29, 2013 | Raymarine St6002 Smartpilot Hydraulic...
Can i find the year of of manufacture of my old johnson 25 hp outboard motor by its serial number?
yes if yuo go to iboats.com the forum will allow you to search by serial number and give info on your outboard.
Aug 17, 2013 | Sierra International 18-4310 Marine...
I bought a jeep motor and i need to know what year model the motor is. Where can i find this?
some of the core and block parts on the motor will have some form of serial number on them to distinguish models and years of the cars they were made for any form of serial identification can help determine your year.
Feb 04, 2011 | Jeep CJ7 Cars & Trucks
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
