Question about Fast Garden
I have massy ferguson 1533 , it starts up but engine runs extremely fast , I can't slow it down . I checked the cables going to carburetor they are fine and lose.
  • 3940 Answers
SOURCE: Fan
No reply
Can't help without details, sorry
Posted on Jun 11, 2008
SOURCE: 1995 nissan pathfinder
I have the same type of codes right after i changed my transmission in my 95 pathfinder. Did you find why you received those codes. A nissan mechanis was not really sure he told me a bad comp maybe and a bad tps.
Posted on Nov 19, 2008
SOURCE: I keep losing my connection plus it downloads super slow
I have the same problem. I have narrowed the problem down to having too many simultaneous connections.I can surf all day long with no problem but when I start downloaded via a torrent or if I play an online game in a room with 32 players, my connection eventually grinds to a halt. No amount of tech visits to your house will ever uncover the problem because your line speeds and voltages will appear normal. Swapping out the modem for another of the same kind won't fix the problem because the issues appears to be inherent in the modem. When downloading torrents you'll have to limit the number of connections your computer will accept.
Posted on Nov 25, 2008
RALilja
  • 390 Answers
SOURCE: 1999 Ford Taurus mechanical problem
your problem appears to be the idle control motor located on the air intake manifold it is a small motor that goes bad quite often. Other items that can cause this is a bad /clogged air filter or a tune up (spark plugs and wires), or clogged fuel injectors. to clean the injectors you can buy a container of fuel system cleaner and pour it into the gas tank and as you drive it cleans the system.
Once the fuel system is cleaned via a tankful of cleaner & gas then the idle controller motor would be next on the list to be replaced.
Good Luck !
Rich Lilja
Posted on Dec 03, 2008
roniecon
  • 6927 Answers
SOURCE: toyota hilux 3ltr diesel,i put new glow plugs in
The glow plug relay maybe bad
Posted on Apr 19, 2010
Massy ferguson MF34A Diesel leaking out from the screw plug on the boyttom of the diesel filter
replace the plug seal or copper washer
make sure that the fuel is not leaking from around the top seal of the filter and running down to that plug
Jun 08, 2017 | Cars & Trucks
MASSEY FERGUSON 1533 BOOM DOES NOT GO UPMORE THAN 3FEET?
check for leaks make sure fluid is at the full mark.
Nov 12, 2016 | Toys
My 7550 exl runs to fast
The generator needs high RPM to produce the right voltage.
Sep 06, 2014 | Electrical Supplies
Engine runs fast and slow
Take a spray of carb cleaner and clean the linkage mechanism from the governor to the carburetor and make sure they move with out sticking.
Dec 07, 2013 | Briggs Stratton Portable Generator 305cc...
358-791010 2 cycle starts bur engine runs so fast...Is there an adjustment? Also, I have no owners manual, that would be very benificial.
There is an idle adjustment screw that adjusts the idle speed of the weed whacker on the carburetor.
Look for the throttle cable, and there should be a screw adjustment in the area where the throttle cable hooks to the carburetor. It will normally adjust with a screwdriver, turn the screw one way and see if it speeds up, if so then adjust the screw the other way to slow the idle speed down.
I hope this helps,
Please Rate Me
May 02, 2010 | Craftsman 25cc Gas Line Trimmer
Lawn mower chugging
better late than never, I have the same mower
there is no throttle control on these mowers, if you look under the air filter the throttle is balanced by a spring pulling in one direction and a lever controlled by engine speed. if the spring breaks or falls off the lever will wiggle back and forth, more gas if the engine slows, less if it speeds up. you end up going fast/slow/fast/slow etc.
The tension spring slows the switching down and smooths out the engine speed.
Jul 11, 2009 | Mtd 22" Yard Machine Push Mower
1981 TOYOTA CELICA -VIBRATION
Hi. I will be glad to provide assistance to you, with the hope that I will get a FixYa rating from you for my advice.
My experience leads me to tell you to check the rear driveshaft u-joint. The way that you describe this would be a worn or seized u-joint situation. Get it checked; I'll bet that that is your issue.
Thanks for choosing FixYa for assistance.
Jan 29, 2009 | 1983 Toyota Celica
Garden Logo
41 people viewed this question
Top Fast Garden Experts
roeb
john h
Are you a Fast Garden Expert? Answer questions, earn points and help others
