Question about Kyocera Office Equipment & Supplies
My kyocera printer tells me error calling the c2000 service that helps :
  • 40 Answers
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
  • 62 Answers
SOURCE: call for service error 7410:0112053 on Kyocera FS3900 DN
most likely the drum popped out.
open the left side cover and remove the waste toner bottle..seated just above the waste toner on the drum unit that sits above will here it pop back into place .. if you hear it snap back it simply power off than back on printer....
if the drum is seated correctly.. than you need to replace the drum unit
Posted on Jan 16, 2010
Testimonial: "This worked, thanks!!!"
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
  • 525 Answers
SOURCE: Kyocera fs 1016 mpf printer
Code: 6400
Zero cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
- Defective the power source PWB
- Defective the engine/high voltage PWB.
Help i dont know how to fix my problem with me kyocera taskalfa 1800... call service c2000
Your drive motor could be faulty, or the drive section under strain, meaning the drum unit could be locked.
Nov 08, 2017 | Kyocera Office Equipment & Supplies
0 Answers machine not working due to error C2000
May 21, 2014 | Copystar CS-1650 All-In-One Laser Printer
Kyocera CALL SERVICE C2000
Drive motor problem Stable OFF is detected for 1 s continuously after drive motor stability. The drive motor is not stabilized in 6 s since the motor is activated.
Poor contact in the connector terminals. Defective drive transmission system. Defective engine PWB. Defective drive motor.
Drive or Main motor problem check whether the drum is rotating well
Nov 13, 2013 | Kyocera Office Equipment & Supplies
My epson c2000 printer have a "service req e033"
Because the Epson AcuLaser Color 2000 was made for Latin America, there's not much information that I can give you concerning your Service Error Condition. All I can tell you is that the Service Request error # E033 is an Engine Related Service Call Error Message for OHP Detection Sensor Malfunction [abnormal condition]. Check to see if the windows on the OHP sensor are dirty and clean OHP sensor window and the OHP sensor reflective window. I'm sorry, but I can't even tell you where the OHP sensor is located, or anything else about it. If you cannot figure it out using your Owners Manual/Users Manual, you can always e-mail Epson Technical Support for possible help or advice, at
Mar 10, 2011 | Epson AcuLaser C2000 Printer
Kyocera FS2000-D error message 7410:0017578
The drum is not pushed fully into the machine.Open the waste toner container door and gently push all units into the printer.Then turn off the printer at the wall.When you power back up the printer should be back to normal.
Jan 28, 2009 | Kyocera FS-2000D Laser Printer
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
