Question about Dyson Vacuums
My dyson will not pick up crumbs or dust unless the Handel is in the upright position .?
DYSON WONT PICK UP
It sounds like there's something wrong with the changeover valve. This determines whether the airflow is directed to the cleanerhead or the wand and I think also provides the resistance to keep it upright. It's the bit above the right wheel as you stand behind it so try taking the inspection cover out and have a close look in that are for something wrong.
Sep 03, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson seems to have lost its suction therefore is not picking up anything yet i have found that when my dyson is standing upright it has a little more suction but nothing like how it use to work. This...
Sorry to hear you're having a problem with your DC07. You should be able to resolve the issue by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1940&product=DC07-SY
If you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
May 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
When the dyson is turned on the suction goes to the wand when you tip the beater down you do not have as much suction you cant pick up lint.
The Dyson system is designed to operate the hose with the handle in the upright position. When the head is tipped down (floor vacuum position) it closes the opening to the hose/wand
Nov 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi my dyson dc07 allergy is not picking up the dirt from the floor or carpet . I have cleaned it's filters emptied it's dust but nothing works
Hi its Darran at Dyson.
The first thing to check is that the brush bar is rotating when the machine is switched on and lowered into the vacuuming position. If it isn't, make sure the brush control dial is in the centre position and moves forward to the on position when the head is released.
Its worth checking the whole machine for blockages as outlined in the user guide or on our website support section at www.dyson.com.
Should you need any further assistance, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Mar 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush nopt turning - only picks up a bit of dust
did you check the belt if it is broken replace it that should do it
Feb 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 bagless - upright mode v poor suction, wand mode ok
From your description of the problem, it sounds as though the bleed valve is activating which only happens when there is a blockage.
We would recommend following the full blockage through as outlined in your user guide or in the Support section on our website at www.dyson.com.
Kind regards
Darran
Jan 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson won't pick up heavier particles -
check the hose line from the base to inlet of the canister, there may be a blockage, like hair or plastic (i had a lego block and hair)
clear obstruction, and check the belt.
hope this works !
Jan 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Spitting Out Debris
the hose from brush go to the bag need to check for blockage you have to open there hose to clean
Aug 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Can't stand upright
Hi.
If you go to the Dyson web site in there help section it shows how to sort out this problem its very easy to do.
http://dysonmanuals.llc.nu/
Jun 01, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
29 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
