Question about Golf
2004 expo golf car takes to much distance to get the rims up. Will not pull a hill unless their is enough flat distance to get up to operating speed.
Have changed plugs, checked valve gap, and changed the air filter. It had been great and just started with this problem.
  • 4102 Answers
SOURCE: loss of power on hills
Hi, i think i answered you in another post.
If not then the likely cause of your problem is turbo related the most common cause is one of the pipes going to the turbo has a small split in it causing this problem.
Nearly all the diesel turbo cars with your problem usually means a pipe needs replacing for the turbo this will need to be checked as it can be difficult to find the damaged pipe because they work under high pressure so actually seeing the damaged part can be difficult so check properly.
If you are unsure then get a garage to check this as they will know the fault and will have a good idea exactly which pipe is damaged.
Worst case of this will be that the turbo needs replacing but this is in the most severe of cases the turbo can blow if the pipe has been damaged for to long as it will be working under the wrong pressure.
What happens is when you acelerate the turbo builds up pressure giving you more power when you need it but when the pipe becomes damaged this pressure is lossed and you then lose power and will cause black smoke coming out of exhaust.
Hope this is some help to you but if you have any problems or questions then give me a shout back and ill be glad to assist you further ok
Posted on May 20, 2008
  • 166 Answers
SOURCE: lossing power
not all hdi injectors are the same and there are some tricks to replacing the injectors so be careful as you can cause saver damage to your engine if not done correctly.
as the other gye said it may be a turbo pipe but Peugeots being Peugeot it could be any thing your best bet is take it into a dealer and get them to put it on the PPS to diagnos it properly
Posted on Dec 20, 2008
DickCanFixIt
  • 948 Answers
SOURCE: SPUTTERING WHEN HOLDING 50-60 MPH
Since it ran fine before you "fixed" it, go back over the things you changed. Put the old spark plugs back in it. Double check all spark plug wires and ignition connections. Put the bike in a dark area and run it at night, can you see any arcing anywhere?
Posted on Jul 01, 2009
  • 713 Answers
SOURCE: 2004 1.4i citi golf not starting well when cold
if your car has plug wires he could have crossed them if it is coil over ignition he could have crossed the plugs for the coils
Posted on Aug 22, 2009
  • 4 Answers
SOURCE: EPC Light on , VW dies when stopping
Tell him to clean the electrical connector at the throttle body with 90% rubbing alcohol. He may want to use a nylon brush on the contact pins while cleaning. I'm pretty sure the car needs a throttle adaptation performed also. Find a shop with a Vag Com scanner, they can do it for you.
Posted on Sep 11, 2010
My 2004 3400 closed system ,runs hot in town unless heater is on. driving up a mountain pass it gets very hot.on a flat highway runs normal. new t state,resivior cap, both fans work no leaks or smell
Radiator fan motor or radiator fan thermostat defective/
Also there is a relay that operates the fan motor
In town not enough air passing through radiator allowing it to over temp.. With heater fan running acts like cooling fan keeping engine cool
Highway driving ample air passing through radiator without fan.
Hill climbing requires cooling fan/
Hope this helps?
Nov 17, 2016 | Cars & Trucks
My 2004 GMC Yukon came with 265 70/16. I put on 245 75/16. Was this ok to do, or am I gonna have problems?
you could have problems as the tire may not be wide enough for the rim resulting in tire failure during cornering
the side wall may be sitting too straight up even out at the rim
best talk with a tire shop as they know the best size tire for the rim or the specified tires for the vehicle will be on the decal on the door or door pillar
the 265 dimension is the rim width ( problem area)
the 75 dimension is the distance of the rim edge from the road ( not a real problem but can affect speedo accuracy)
Oct 01, 2016 | 2004 GMC Yukon
Cant get my gas powered ezgo golf cart to go up
Itsounds like you're not getting enough fuel to the cart. Then again your drive belt may be slipping which is not allowing the centrifugal clutch to move your car up hill. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Oct 13, 2014 | Golf
My golf 4 automatic 2.0 does not change gears is stuck in a highest gears,, if i press the petrol petal flat is increasing speed very very slowly,, so i can over take, i pull up hill very slowly and c
Your vehicle is in the limp home mode due to the transmission fault code. The computer will not allow it to shift. You need to take it to a shop unless you have experince with auto transmissions
Oct 06, 2014 | Cars & Trucks
Losing speed when going up hills
catalytic converter. get it tested. Might be the fuel filter clogging up.
Apr 06, 2014 | 2004 Chevrolet TrailBlazer
Just bought one of these and it seems like it doesn't hold a charge it goes pretty good and thanafter 15 mins so slow??
Battery powered vehicles like scooters and golf carts have trouble going up hill because smaller electric engines aren't powerful enough or made for nothing more than flat land. You could have a bad battery or the battery isn't being charged enough. I know someone that has a golfcart and it takes approximately 48 hours to charge full. You may want to check the manual about charging times.
Sep 16, 2012 | Razor E200/300 Electric Scooter Battery
Trying to change tyre and wheel wont come off
I was wondering whether you had it on a jack or not. Make sure the flat clears the ground before you start pulling it off.You can't be too rough or you will have the car fall off the jack.What I am guessing at is that the centre hub hole is not large enough for the dust cover of the wheel bearing in the center. Non stock rims sometimes come that way....you gotta grind the centre hole larger.
Now to get it off. If it is in the air, take a sledge hammer and do some "putting - golfing" with it and sledge the rim (from the outside hitting the outside of the rim)on the lower portion, then rotate the rim 180 degrees and do another putt. If you hit the bottom, the top should flip outward toward you. Then do a 90 degree turn and give it a similiar smack.If the rim does not seem to move at all, then you are gonna have to hit it from the inside outward. BUT FIRST SHORE UP THE CAR, OVERDO THE BLOCKING,,,JUST MAKE SURE THE CAR DOES NOT COME CRASHING DOWN ONTOP OF YOU.Oil, grease, heat will not work here. You bolted up tight a rim that did not fit on correctly. Make sure that the centre hole is more than big enough. That won't affect the trueness of the wheel, the bolts hold the wheel in the centre. Jobber rims do not fit well. You will be using a grinder.If you have a dead blow hammer you might try tapping the rim to help break it loose. Can you get a pry bar in there to help? Just be careful when you tap the rim, do not dent it. The sharp blow will do more good than just trying to pull it off by hand.
Nov 02, 2011 | 1998 Honda Odyssey
What gear to drive in when towing a trailer with toyota camry
Whatever gear the car needs to have the moter spinning without full throttle.Auto and manual are driven differently.Up hill,downhill.Mostly,if its manual you wait a bit longer to change gears.E.g.Normal change revs,3000 rpm,go to 3500rpm with the trailer on.Auto,use the gear selecter and put it back to 3 instead of D and when the car has enough speed,then into D.Drive the auto like a manual on hills etc.to help it.Don't forget that braking distances almost double when you have a trailer on.Hope this helps
Nov 20, 2009 | 2004 Toyota Camry
No matter what surface flat or hill or any speed it feels like im driving up a steep hill transmisson fluid is fine could this be caused from a faulty overdrive
Go for a drive,pull up and feel the heat of each wheel rim.If one or all are extremely hot,the brakes may be binding.I would check this as a first step.Hope this helps
Sep 30, 2009 | 1995 Jeep Grand Cherokee
What is the maximum size of wheel that i can put on a Golf 97 CL
In theory, you could go up to a 17" rim with an ultra-low profile tire. The stud configuration on the Golf, however, makes it hard to find the larger rims, and the ultra low profile tires are very expensive. Your best bet is to take it in to a tire shop to find out what can be ordered for the vehicle. If you wanted to order sets online, make sure you measure the distance between the studs and the depth of the wheel.
Jul 17, 2009 | Volkswagen Golf V Vw Scale Diecast Model
Golf Logo
281 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
