Question about Husqvarna Sewing Machines
Does anyone know what kind of motor, Servo or clutch, is in a HUSQVARNA huskylock 1002LCD? Also does it zig zag?
  • Husqvarna Master
  • 11,493 Answers
The information I found about your machine indicates it is a serger, not a sewing machine. A serger does not zig-zag.
Posted on Apr 19, 2017
  • Julie Reyes
    Julie Reyes Apr 20, 2017
    Thank you R.A. Ellis! Would you happen to know if this machine has a clutch or servo motor?
  • R.A. Ellis
    R.A. Ellis Apr 21, 2017
    Sorry. No idea. You might ask a technician at a Viking store.
SOURCE: Husqvarna 2000 sl no zig zag movement
You might try oiling where the needlebar slides side to side (and everywhere else). More than likely it needs to be freed up somewhere.  Also there is a small piece called the cam follower that can pop off. Look inside near the cams and the piece with a finger that follows the cams may need to be reattached. They do come loose sometimes. Good luck.
Posted on Oct 18, 2007
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
  • 65 Answers
SOURCE: No "Zig" to my "Zag"
I Love the support Brother gives!
Here's what Brother says about the Zig zag issue.
your manual (download)
Posted on Jan 27, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
Posted on Feb 16, 2009
  • 208 Answers
SOURCE: I cleaned my Husqvarna Viking 6690 and now it
I hate to say it, but the 6690 was plagued with circuit board problems. That machine cost Viking a lot of heartache. I'm a bit surprised to see one still working. You didn't specify exactly what you did when cleaning or whether you took the covers off and disturbed the wiring. Check all the connections and plugs, but it might be dead. You can take it to a Viking dealer with experience with the 6690 for an evaluation.
Posted on Feb 21, 2010
What do I set my machine for to make very close zig zag stitch. Husqvarna Viking platinum 755.
With most machines after you select the Zig Zag setting you then select the normal stitch knob that can be adjusted for long or short stitch lengths and that should also give you adjustment on your Zig Zag stitch length .
Nov 03, 2017 | Husqvarna Sewing Machines
What is the difference between a clutch motor and a servo motor in sewing machines?
clutch motor is the motor that starts working when you put your foot on the peddle
Apr 19, 2017 | Husqvarna Sewing Machines
How to set machine for zig-zag?
What is the model of your machine?
Check user manual. Manuals are available to view, download, or print from husqvarna viking website -
Jun 18, 2014 | Husqvarna Sewing Machines
Viking 6360 buttonhole procedure
you start with the broad zig zag stitch bar across the top
then you go down the left side using a smaller zig zag stitch
then you make the the broad zig zag stitch at the bottom
then you make the smaller zig zag stitch on the right side
all the way to the top broad zig zag stitch & your done
the right side zig zag does not go beyond the top broad zig zag
Aug 01, 2012 | Husqvarna Sewing Machines
I need to adjust the needle so when I zig zag it will not hit the plastic. It works perfect on stright stitch.
You might have the zig zag set for z-z left or right-hand. Make sure you are choosing the zig zag centre stitch. Also check you are using the correct foot - it should be the A or B foot with the wide opening.
Apr 06, 2010 | Husqvarna Viking 1
I have a huskylock 1002lcd serger. The cutting
See an authorized husqvarna viking dealer for parts (and service). It's possible you might find the part at third party vendors on line but your best bet is with an authorized HV dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page -
Good luck.
Dec 24, 2009 | Husqvarna Viking 1
Hello! Our Huskylock 1002LCD machine is speaking
Hold in the "A" button and the up arrow button at the same time and turn the machine on, you can then scroll through the different languages the machine can display using the "A" and "B" buttons.
Oct 06, 2009 | Husqvarna Sewing Machines
Zig zag stitch & manual Husqvarna 5310
What numbr on the dial of the Husqvarna daisy is the zigzag??
Sep 05, 2008 | Husqvarna Viking 1
Sewing Machines Logo
35 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
