Question about The Audio Players & Recorders
SOURCE: rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Posted on Sep 16, 2008
SOURCE: Title Rack will not turn with service or arrow buttons
It sounds as if you may have a problem with the mechanical element of the title rack.
Try to move it manually.
If it is moves easily the problem will more than likely be the motor or the Display Unit.
If that is the case you will need help from your Rowe Ami dealer.
Regards
Alan Hood
ami-man
Posted on Feb 27, 2009
SOURCE: Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Posted on Nov 04, 2009
SOURCE: I have a Rowe R-89 jukebox. Even though the motor
Hello Robert,
You say you have a R-89 jukebox and the turntable motor is running, I assume that the pulley on the top of the motor is clearly seen turning. Is the turntable belt loose or missing?
From your message I am not sure that your jukebox is a R-89, could it be a 1978/1979 R-82 or R-83 that uses an idler wheel.
On this model the turntable motor is 110 volts AC.
If the above is true check that the idler wheel and the linkage spring is pulling the idler wheel against the turntable and the motor shaft.
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
Posted on Aug 31, 2010
SOURCE: Transferring Vinyl from Kenwood P26 Turntable to PC
Argos has a turntable for 90 pounds which converts Vinyl to MP3 or wave . There are similiar versions for cassette tapes. If you need help finding one. let me know
Posted on Sep 19, 2010
Aug 30, 2016 | Audio Players & Recorders
Mar 27, 2014 | Audio Players & Recorders
May 18, 2013 | Wurlitzer Jukebox CD Player
Mar 14, 2010 | Audio Players & Recorders
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Oct 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
Sep 01, 2009 | Audio Players & Recorders
Jun 09, 2008 | Audio Players & Recorders
53 people viewed this question
