Only 100 is working, other channels not active
How can I Watch Music Channels on Your Roku
Roku has variety of channels including music channels. Roku's music channels feature popular streaming apps along with music and videos in every imaginable genre, including classics.
• iHeartRadio
• VEVO
• Tiny Desk Concerts
• Pandora
• Baeble
• TuneIn Radio
• Amazon Music
• AccuRadio
• Classic Country Music
Get complete information about Roku sports channels, news, movies, TV shows etc.
Roku channels Archives Roku com link Activation Support
Sep 27, 2017 | Roku Televison & Video
Tip
Harmony remote always sets TV to channel 3
So I have had this a few times where the setup wizard for the Watch TV Activity not only asks what input the TV has to be on, but also what channel. A lot of the time I got annoyed when the channel would always goe to a particular one (usually 3) at the beginning of the Activity.
Unfortunately, we can not get rid of this setting, although there is a workaround. If we go through the setup for the Activity again, and select the channel to be '0' for the Activity, in most cases that will work.
When most TV's receive a '0' channel command and no other numbers, it disregards the command and stays where it is.
Hope it helps
on Mar 18, 2010 | Audio Players & Recorders
I have starz thru mediacom. Got code from roku smart tv to activate starz. can't get to screen to put in code.
Activate Starz Com is a most watched & popular Channel. If you are a Roku user then you can easily watch starz.com/activate on your Roku TV. That is accessible to stream videos & movies online from Roku Com Link. If you find any difficulty to activate and subscribe Starz on your Roku device, then please let us know anytime. You may also read blog that based on Starz Com Activate at
"Activate Starz com How to Activate Starz com on your Roku"
Dec 25, 2016 | Roku Televison & Video
I would like to activate pbs
If you like to activate PBS on your Roku 3, and then do the following activation steps one by one.
1. Go to the Roku home screen and type "PBS" on Search Box.
2. And Select the PBS from the search list.
4. Once loading is completed click "Go to Channels".
5. Copy the seven-digit number from the displayed screen.
untitled6-qizfbljhmmqbswp3ibggqyqd-3-20.png6. Then open the web browser from any one of the devices.
7. Go to the pbs.org/activate and enter the activation code here.
8-qizfbljhmmqbswp3ibggqyqd-3-27.png8. Click Continue for the PBS Activation.
For more information about the Roku Activation or PBS activation call us at 1-855-804-1313 or visit us at https://www.rokucodelink.com.
Oct 04, 2016 | Roku 3
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
Does a Regency Toutch K 100 20 channels S1&S2 Does it scan all 20 ch at the same time, S1- ch 1 S2 ch 11- 12 Etc??, what is a d code mean?
Your Regency scans (samples) the programmed frequencies at the rate of approximately 15 channels per second, so it is constantly checking for an active frequency. "D-code" code refer to any of a number of things. Do you have the term in context?
Nov 20, 2009 | Radio Shack Radio Communications
How to increase channels on Old BPL TV
hello sir, iam having a BPL tv,with 100 channels,,,the problem is i cnt watch around 50 channels,even the cable operator provides 100 +. there are three bands coming while tuning,L,H and U.am getting channel during L,H,but when it goes to U,then everything is blank...U(UHF) is starting from around 55,so all channels are blank upto 99. could you please help me???
Sep 11, 2009 | Televison & Video
Conversion to home theatre
You will need a separate stereo amplifier for the 901's to accommodate the need for the Active EQ. There is no way to separate your receiver's front L&R channel preamplifiers from their amplifiers.
I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's. If your receiver requires a powered Subwoofer so you would need another amplifier channel for that, too. Therefore, you might look around for a powerful 3- or 4-channel amplifier so you could drive the Sub, too.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Not what you might want to hear but 901's have special requirements. I've had mine for 25 years and have no regrets.
A separate subwoofer channel on the amp could be used. Just run a single RCA channel from Sub OUT to one available channel IN on the amp and attach the subwoofer to it. Two would work, also. That's what I do. You could use a 1-2 RCA splitter to feed two available channels on a 4-channel amp. The iterations are many. Have fun.
Jan 19, 2009 | Bose 901 VI Main / Stereo Speaker
Subwoofer: Active or non active?
Hello Smegboy,
Yes, you are right. This receiver is rated at 100WRMS output in all 5 channels (2-front, 1-center and 2-surround) while in Dolby Pro Logic operation. The subwoofer output is line level only (not amplified), which means you need a powered subwoofer to be connected to this output. A non-powered subwoofer could be used but, you need an additional amplifier connected to the subwwofer output from the receiver to drive it.
Let me know if this helps.
cancerags
Dec 29, 2007 | Technics SA-AX710
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
