Question about Brother Office Equipment & Supplies
Total usage of fax
I want to know how to tell the total usage of the Brother 4100e fax.
leroyal
  • 2120 Answers
SOURCE: Cannot receive fax with voip line.
Fax machines are ANALOG devices. Any other condition is a ****-shoot.
Posted on Sep 01, 2008
BigdaddyTDW
  • 62 Answers
SOURCE: I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Posted on Feb 14, 2009
MalKontent68
  • 748 Answers
SOURCE: Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Posted on Nov 07, 2009
SOURCE: need maintenace codes for brother 4100e fax
Power off the printer for 15 minutes and power back on again. If that fixes the problem then OK.
If not then go into maintenance mode -
Press and hold the menu/set key while turning on the machine. Wait until it comes completely up before releasing. It should say Maintenance in the display.
If not press function,*,2,8,6,4 within two seconds. It should say maintenance in the display. Or on some machines Menu,*,2,8,6,4 within 2 seconds.
Once you get it into maintenance hit 91 to do a parameter reset and than 99 to get out of maintenance.
You reset all Brother fax machines the same way. Press function, *, 2,8,6,4 all within 2 seconds to place the machine into the maintanence mode. Press 0,1 to perform a parameter reset. this will restore the machine to factory default settings. press 9,9 to exit maint mode.
Procedure is:
1) Unplug machine.
2) Hold down menu key. Plug in machine.
3) Release menu key.
4) Enter 91
5) Enter 99
6) Machine will warm up.
7) Press Reports key, then 1. This will test if the machine can
print.
http://www.brother-usa.com/manuals/default.aspx?PGID=2&R3ModelID=PPF4100
Above link is for the user & setup manuals. The codes are in there.
Posted on Apr 06, 2010
Testimonial: "I don't need to pursue because I got the repair manual from Google. Thanks for your help."
Jimsta01
  • 405 Answers
SOURCE: printing confirmations
Press MENU button, then the numbers, 2 ,4 ,1. Then press the left and right arrows to find On and then press the SET button.
Posted on Jun 06, 2010
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
Customer with Brother Intelifax 4100e cannot "handshake" with our Savin 816 multifunction. The Savin is receiving hundreds of faxes daily, and is also used to scan to document management, etc. ...
I have a fax line with packet8 which is a voip carrier. I am having trouble receiving faxes. I was told to change the baud rate on the fax to less than 9600. I don't know how to do it on my brother intellifax 4100e. can you advise?
Thanx,
Mar 22, 2011 | Brother IntelliFax-4100e Fax
Nov 07, 2009 | Brother IntelliFax-4100e Fax
When sending a fax on our Brother Fax-4100 the person on receiving end of the fax says it comes across totally black What is the problem??
If you make a copie. on your fax.
That is the same quality that you are sending over the phone line.
If the copie is total black
lift the document feeder see if there is anything on your optical glass.
But my experience tells me that the lamp has gone out also know en as the scanner asm.
let us know what hapens
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax-4100e changing Pick up roller
Push the arms that limits the lifting up of the feeder outboard to release the freeder.
Feb 05, 2009 | Brother IntelliFax-4100e Fax
4100e brother fax i am unable to receive fax
if you are getting dial tone, then go tto the receive set up and scroll down to easy receive and then press set
Dec 30, 2008 | Brother IntelliFax-4100e Fax
Aug 12, 2008 | Brother IntelliFax-4100e Fax
21 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
