Question about Garden
I have an old john deer I think 1982 put new ignition on and solenoid and batt. turn key I get nothing it will start if you jump across. but turn key nothing.can you show me wiring
  • 923 Answers
It will start if you jump across WHAT? The electrical terminals on the key switch? The solenoid actuating terminal to ground? Need more info!
Posted on Apr 18, 2017
John deere la 145 wont turn over
could be the battery the solenoid or the starter . or one of the safety switches or the blade PTO
Aug 09, 2016 | John Deere Garden
I have a 2008 la 115 john deere riding mower. It won't start in less I put a large screwdriver on the solenoid. the fuse looks good as well. I replaced the ignition switch and solenoid too.
When you try to turn over engine with key it turns over slowly and stops? It acts like starters not working properly? If this sounds like it and it's a single cylinder Briggs and Stratton engine ohv's your valve specs are off they need to be checked and adjusted every 200 hrs. If you need further assistance let me know. or call 831-578-4034 pacific standard time ( California)
May 18, 2015 | John Deere Garden
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 855 Compact tractor has no power to solenoid
Power from the battery direct to a big terminal on the solonoid. The other big terminal leaves the solonoid for the starter. Then there are either one (1) or two (2) smaller terminals on the solonoid. If there is one then the body of the solonoid is the ground. With two of course the extra is the ground. Make sure the solonoid has a good ground.
Remove the smaller terminal from the solonoid ( usually yellow) and connect the positive end of a multimeter or a DC volts tester to it. ground the other end of the tester and turn the ignition key to start. If you get 12 volts to the wire end then the solonoid is bad and should be replaced. If no voltage is registered then the ignition switch is bad or an inline safety switch such as: nuetral, clutch/brake, PTO, seat ( Operator Presence Switch). Or you have a bad wire, bad ground, bad connection somewhere in the starting system.
Oct 31, 2012 | John Deere Garden
John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Mar 28, 2012 | John Deere Garden
1985 bronco II wont even turn over.
I think it has some thing to with a relay maybe.
Nov 04, 2017 | 1985 Ford Bronco II
John Deere 425 AWS no start, no nothing???
Sounds more like a bad starter than a bad coil.
A failing coil usually shows up during hot weather. The engine will start and run fine, then when it heats up, it just dies out. After a few minutes, it cranks again. Then the cycle repeats itself.
The ignition module and coil pack are the same part.
Are you sure full voltage is getting to the starter? There is likely a starter solenoid between the ignition key and the starter. These solenoids can be problematic and prevent the full 12 volts from getting to the battery.
Oct 16, 2009 | Garden
First problem won't start unless I jump across
Okay I want to say get an ignition switch for the starting problem. The wire that makes the solenoid work comes from the s terminal on the ignition switch. The ignition (i) side of the ignition switch goes to the coil. The running and dying could be the coil. Both wires start at the ignition switch. Check those two wires for connections. Take out the switch and see if the (i) and (s) terminals do anything when you turn the key.
Jun 30, 2009 | 1987 Ford Ranger
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
