Question about Viore Televison & Video
I have a VIORE TV model LC20V21. I hooked up a HD air antenna and rest TV to air and scanned but no channels coming up after full scan.
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
MNfisherman
  • 11896 Answers
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Posted on Jun 22, 2009
  • 556 Answers
SOURCE: Not able to scan for digital OTA channels on a JVC LT-32X667 LCD
Seeing as it does not have a digital tuner in it, I would think this would be the problem, you will have to get a box for it.
Posted on Aug 25, 2009
Mike258
  • 1498 Answers
SOURCE: I am still trying to scan the air channels, I am
Hi Tat2,
First: If you do not have a cable hookup, if you are using an antennae, you should get a converter box.
It handles the scanning, the decoding of sub-channels (I have four OPB channels), signal strength filtering. It's remote, controls both the box and your TV.
It hooks up between your TV and antenna. Set your TV to channel 4, click the on button. The first time menu comes up, scans the channels and lets you know when its done. You'll find channels you never knew existed.
They're easy.
Best regards
Mike
Posted on Aug 26, 2009
SOURCE: how do i get local channels on my Samsung tv? i
HLP4663W is not able to receive digital channels. You need a digital tv converter box to receive those digital channels.
Posted on Oct 03, 2009
I want to hook up my old 1992 Sylvania TV to HD Antenna, but I cannot figure out how to scan or auto-program the channels. Model SRC1351 101
Hello... Somewhere in the same menu as the Air/Cable setting should be an option to scan for channels. It might be called Auto-Program, or something similar. The bad news is that: "On June 12, 2009, the Federal Communications Commission (FCC) mandated that all U.S. based television signals must be transmitted digitally." Since your TV was manufactured in 1992, it isn't capable of detecting or displaying digital channels. If you're really fond of the TV, you will need some sort of conversion box. If you can afford to, I'd recommend buying a new TV, and get the extended warranty. I hope this helps!
Nov 26, 2017 | Sylvania Televison & Video
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
Do I need an hd convert box to get free channels
If you have a digital tv then no. Go to menu, click on input, click tuner or tv, click antenna, run auto scan for channels. Make sure antenna is hooked up. Digital antenna is preferred but not mandatory. If you're not getting channels move antenna re-scan for channels. Hope this helps!
Jan 29, 2016 | Televison & Video
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
Aug 27, 2011 | Sony BRAVIA KDL-46V3000 Television
How do I set up my tv, for auto scan I thought I needed a digital converter, I just learned that I do not. Do I need an antenna of any kind at all. I am very confused. I really would like to talk with...
If you are trying to program free HD off air you will need a UHHF antenna attached to the ATSC hook up on back of TV then have TV scan for channels available. If you are hooking up a "cable" box or satellite receiver that will just get hooked up with the output of the box going to an appropriate input on your TV. If you are just taking a cable from wall (being used as an antenna) then hook that up to the QAM antenna connection on tv and scan for channels once that is hooked up.
Hope this helps - if not please be more specific on what you are trying to hook up to what input.
Mar 08, 2011 | Televison & Video
How to hook up to hd tv
Use the highest resolution connection your HD TV will allow. This will usually DR570's HDMI connector. Most all digital video devices have one or more. The DR570 has an HDMI OUT. Connect it to any HDMI IN connector on your TV. You will then need to set the TV's Input selection to the Input Number you connected the DR570 to. See your TV Remote or Manual.
The DR570 has three types of output connection options, in order of quality; HDMI, Component(Red/Blu/Grn RCA jacks), S-Video (circular connector), and composite (Red/Wht/Yel, where Yel is video and Red/Wht are left/right stereo audio). Red/Wht RCA Audio jack connections are required to be made on all Output types excepting HDMI.
Note, to get your Digital channels, you will need to toggle the DR570's DTV/TV button. DTV is Digital TV channels. TV is analog channels, the DR570 found on your Cable or Antenna RF input coax, after you have done the Setup/General/Channels/Scan (extended). Scan only finds analog channels. Extended Scan scans for both Analog and Digital channels found active on your Cable/Antenna RF connection.
Note also, the DR570 is not technically and HD receiver. The term High Defintion (HD) is reserved to mean 1080i or p resolution, the highest available. The DR570 is an Extended Definition (ED) 720i or p receiver. It up-converts its ED to fit an a 16:9 HD TV screen. You will hardly notice the difference on your TV, but it is the difference between watching a DVD Movie on a standard DVD player, like this one, as opposed to a full HD player like a Blue Ray.
Feb 01, 2011 | Toshiba DR570 DVD Recorder
My viore lcd tv model LC20V21 wont turn on anymore. Any suggestions?
MY VIORE 42NAFC MODEL COMES ON AND SAY PLEASE WAIT AND SHOWS NO PICTURE
Mar 22, 2010 | LG 42LC2D 42 in. LCD HDTV
I am still trying to scan the air channels, I am hooked up to an antenna and can only get the Spanish channels. How do I get all the digital channels?
Hi Tat2,
They're easy.
Best regards
Mike
Aug 08, 2009 | TruTech PVS31170S1W 17 in. LCD Television
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Televison & Video Logo
44 people viewed this question
Top Viore Televison & Video Experts
Tom Chichester
Brandon Murphy
George Scott
George Scott
Are you a Viore Televison and Video Expert? Answer questions, earn points and help others
