Question about Troy Garden
I have a 2015 Troy Bilt Pivot S ZTR 54" mower. It was running fine when last used Sept '16, but now it womt start. It has fuel, battery shows a full charge & oil is full. This widow needs help!
    Master:
  • 923 Answers
Does the engine crank when you try to crank it? Or does it completely ignore you? What do you mean by it shows a full charge? Do you mean the battery?
Posted on Apr 18, 2017
  • Ms Shultz
    Ms Shultz Apr 19, 2017
    No it doesn't crank, just a click. Mower has a digital readout, when I turn key to ON, that provides info: oil level, hours of use & battery charge amount (21.7- full chg acc to manual). Also hooked battery up to charger, but that also indicated a full charge. Gas tank is full, PTO knob in OFF position, oil is new & at proper level, parking brake on, mowing deck disengaged. Have read & re-read manual. Didn't take battery out after last use though. Buy new battery perhaps? I'm so frustrated, bc am very capable w/power tools, etc.--but no mechanic. Thank you for responding.
  • solver2010 Apr 19, 2017
    If you hear a click when you try to start the engine, then the problem is very likely the battery. However, is is possible that the problem is corrosion on the battery terminals! To give you an idea what happens when battery terminals or connections become corroded, is limits the current that can be delivered to the starter. The voltage may be just fine, but the starter needs a lot of current to turn the engine. What would happen if you had a 12 volt headlamp in electrical series with the starter? You would see the lamp come on, but almost no voltage would reach the starter! I doubt that the starter solenoid would even click! Remember, when you clean battery terminals, you are dealing with ACID, so wear rubber gloves, and eye protection ... regular glasses are not enough because of air gaps around your eyes! I would use a stiff wire brush, and I would recommend that it have brass bristles so the acid won't corrode the brush! After the connections are pristine clean, use some new automotive grade grease to cover all metal surfaces involved, ESPECIALLY where the metal will be HIDDEN after you put it all back together. Starvation for oxygen is your friend when trying to prevent acid-induced corrosion!
Any videos on how to change an ignition coil on a Troy bilt tb30?
Hmm, good question,
would this be of any help?
It look like # 39 is the coil and 38 are two screws that hold it on.
Troy Bilt 13B226JD066 TB30 2015 TB30R Neighborhood Rider 13B226JD066 2015...
May 06, 2016 | Troy Garden
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Troy-bilt 550 series mower won't start. I've only used it twice.
does it crank over?did you leave the blades on?are you pushing on the brake pedal
May 25, 2012 | Troy Garden
I have a Troy Bilt 175 HP 500cc 7 speed riding mower. I just bought a new battery, and it still won't crank. It'll turn over like it wants to, but nothing. I put new gas with the old gas from last season...
If you didn't put fuel stabilizer in gas before letting the mower setup all winter, your gas has gunked up your carb.
You can verify this by removing the air filter and spraying starter fluid in the carb. If it cranks with the starter fluid, the carb is dirty.
Pull the carb and clean it out
Dec 08, 2017 | Troy Bilt 175HP Manual 42" Riding Mower
We have a troy bilt snow blower 1 yr old and we are trying to start it. When we try to prime it, the primer bulb does not seem to be moving any fuel. It just sounds like air. It will not start. We have...
Are there two tubes connected to the back of the primer bulb?
If it is connected, then the primer bulb itself could be cracked, allowing air to enter, but not fuel.
See if you can gently pry or possibly unscrew the bulb for replacement. They are readily available.
Gary
Dec 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Garden Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
