SOURCE: engine will turn over but will not continue to run
the fuel filter is in the tank on top of petcock that bike has a vacum operated petcock(fuelvalve)if the vacum hose is bad no fuel flow check the back of the fuel valve for a small hose that goes to the manifold make sure it is good put vacum on the hose wile hooked to the fuel valve and make sure that gas runs out of the hose give me a rate please hope this helps
SOURCE: lack of power when climbing hills and slow to pick up speed
It sounds like your vehicle needs a major tune-up. Try putting in some fuel injector cleaner gas additive and a new air intake filter.
SOURCE: won't pull itself up hill
You didn't indicate what model of tractor you have but most likely it is a hydrostatic drive problem . The power is transfered from the engine to the wheels by hydraulic pressure. If the fluid level (hydraulic oil) is low then it won't drive correctly. Follow the owners manual to check the fluid level. The other possibility is if this is an older unit it could actually have water in the oil.The water will not operate correctly. Where did the water come from? The transmission housing, is vented to atmosphere. On a hot humid day, while you're driving, the fluid and housing is heated. When the tractor cools, the ambient humid air enters the housing. When night rolls aroound the water condensing inside the housing. If you're lucky this transaxle may have a drain plug in the bottom. You can remove this and see if the oil looks milky. If it does, I'd drain it all and refill with fresh oil.
