Question about Samsung Dishwashers
Hi..I have a Samsung DMS500TRS, dishwasher, and no power. Please help. I have opened th front panel,looking for a fuse, but not sure what it looks like
    Top Expert:
  • Samsung Master
  • 76,848 Answers
This is not a fuse issue, the control panel has failed. Cost to repair for parts and labor about $300.00 US dollars
Posted on Jul 09, 2017
jsrock516
  • 5911 Answers
SOURCE: Power to dishwasher and will not run
Check your thermal fuse. It will be inside the control panel, clipped to the control board somewhere. It's usually a white plastic square piece with two wires connected to it. The fuse should read a short. If the fuse is blown, you will need to replace it. If the fuse reads good, I would suspect you have a control board problem. Make sure you secure power to the dishwasher BEFORE you take any resistance checks, however. Even if the fuse is blown, you could still have live voltage on one side of the fuse. If you cannot find the fuse, there should be a tech sheet with wiring diagrams inside the lower kick plate below the door. This could be a tremendous help you as well. Let me know what you find.
Posted on Jul 14, 2007
reg501
  • 413 Answers
SOURCE: Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
Posted on Jun 22, 2008
SOURCE: front door panel, stainless for GE dishwasher
Ebay has a guy selling stainless panels, cut to size; search dishwasher stainless panel
Posted on Nov 11, 2008
SOURCE: Infiniti G35 trunk won't open
I had this problem as well.
The wiring harness in the trunk is a bit short and some of the wires fray. when this happens, the car doesn't recognise that the fob is close by so it fails to open.
Just pull back the boot near the trunk hinge on the passanger side and look for frayed wires.
Posted on Dec 11, 2009
SOURCE: Change Fuse on Fisher Paykel Dishdrawer
I have a single drawer F&P dishwasher. This morning a safety switch trigged. This afternoon when I went to use the dishwasher found that it had no power. There are no lights and there was a smell of something burning. The power outlet has power. Can you help?
Posted on Feb 14, 2010
Samsung dishwasher DMR57LFW/XAA will not power on. Want to check the fuse, but do not see it in the lower right under the white panel. Am I looking in the wrong place?
There is no internal fuse that I am aware of, if it will not run then more then likely the control panel is defective.
Apr 11, 2017 | Samsung Dishwashers
I have a Samsung dishwasher model DW80J3020UW that won't power on. Some sites suggested replacing the thermal fuse but I can't find it. It's not on the control panel. Help!
It is not that easy! When you power on the unit, it runs diagnostics on itself. If it doing that you should be able to hear it If you have it wired directly into the power then you need to switch off the breaker and then turn it on again. Listen for the pump etc and see if it makes noise. If you get nothing at all then you need to pull the unit out from under the counter and use a meter to check the wiring. The wires that run to the control panel flex when the door opens and closes, they break. Check the transformer on the control board. http://www.appliancepartspros.com/samsung-assy-pcb-main-dd92-00033c-ap5800462.html that is a picture of the board and the transformer is on the left half. There may be fuses there but they might not look like you expect.
Jan 02, 2017 | Samsung Dishwashers
Thermal fuse
http://www.partselect.com/MultiModels.aspx?ModelNum=KUDS35FXSS&SearchTerm=fuse&RefineSearch=0
Maybe this link will help
Jan 29, 2013 | KitchenAid KUDS35FXSS Dishwasher
There is water on the bottom and no power
It sounds like you lost power during a cycle. It is most likely the thermal fuse.
Take a look at this link I put together it will explain the places you can loose power to a dishwasher but on this model I would suspect the thermal fuse. If your model is KUDU02FR the part number for this fuse is W10258275, it looks like a small cylinder with two wires attached, it is on the control board in the upper door, removing the screws from the inner door will let you take the front panel off and expose the control.
http://www.fixya.com/support/r4689610-wont_start_or_dead_dishwasher_no
May 03, 2010 | KitchenAid 24 in. KUDU02FR Built-in...
The water doesn't stay at the bottom of Dishwasher & The detergent doesn'e get totaly emptied out from detergent Tray. It looks like the the residue remain in the Dishwasher & On Dishes too. Please, help...
hi there,
no indication that machine is not working,is there any power supply,check the power source,circuit breaker switch on.
Step 1: Check to make sure it's receiving power. If the unit plugs into a wall outlet, check the cord, the plug, and the outlet to make sure they're functioning properly. Also check the switch that controls the outlet to make sure it's turned on. Most built-in dishwashers are wired directly into a circuit. Check the main entrance panel for a blown fuse or tripped circuit breaker, and restore the circuit. If your home is an older one, the dishwasher may be wired to a separate entrance panel; look for a blown fuse or breaker at this panel, and restore the circuit.
Step 2: If the circuit is receiving power, and the wall outlet is controlled by a switch, the switch may be faulty. Test the switch with a voltage tester. Take off the switch cover plate and place one probe of the tester on one terminal and the other probe on the other terminal. If the tester bulb lights, the switch is functioning. If it doesn't light, the switch is faulty. Replace the switch with a new one of the same type.
this should be done by appliance technician,but if you have knowledge on this check it out.regads have a nice day,dont forget to rate me thank's
Apr 30, 2009 | GE 25 in. Profile PDW8200J Built-in...
Kenmore standalone dishwasher just stopped mid cycle. Can't start
usually when this happens you have a bad fuse. open the door you will see screws that line the inner door take them out. you need to get to the control panel the fuse is usually attached to the panel usually looks flat and white and has 2 wires going to it usually black with a white tracer. some have round metal looking fuses with 2 wires going to it as well sometimes they are brown wires. locate the fuse this will more than likley be your problem. make sure there are no burn marks on the board. unplug power first before doing any of these checks
Apr 09, 2009 | Kenmore Dishwashers
Where are the fuses for the auxillary power outlets located?
Hi there;
The fuse you are most likely looking for is in the Instament panel fuse block located in front of your left knee. It is a 20 amp fuse & is simply labled AUX. AUX 2 is for the rear outlet.
There is a fuse block under the hood, the fuse you are looking for is a 20 amp fuse & it is in possition #53 that is for the upper outlet in the front.
hope this helps
Farrout!
Mar 18, 2009 | 2007 GMC Envoy Denali
Smeg Dishwasher - model unknown
model numbers for dishwashers are generally where you can get to from the front, if they are noit on the front panel then look inside the door rim where the rubber seal is, either a small sticker on the door rim itself (inside) or where the door fits on the main cabinet, open the door fully to look for this sticker, sometimes placed under the front of the lid
Sep 28, 2007 | Smeg CSU2001 Built-in Dishwasher
Jul 13, 2007 | Kenmore 24 in. 16332 / 16334 / 16339...
Dishwashers Logo
103 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Di Nagy
Di Nagy
Level 1 Expert
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
