Question about Navman GPS
Extension aerial for navman i650 - Navman GPS
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Navman Expert
  • 184 Answers
This is not a question
Posted on Apr 21, 2017
I got navman s30 Satnav got no gps signals any advice?
Probably a faulty aerial inside the unit. They are not replaceable so it would be best to replace it (Cheaper than sending it back to the manufacturer).
regards
Graham
Apr 13, 2012 | GPS
How do i reset a navman s30
Insert a Needle or straightened out Paper Clip in the Side of your Navman S30..It,s on the left Hand Side ( while looking at the Screen) 7 it is covered with a Rubber Plug..There are 2 Holes under this Plug--1 is for an External Aerial & the other is the Reset Hole...
Hope that Advice helps
Oct 01, 2010 | Navman S30 Car GPS Receiver
My navman icn 320 keeps searching for gps signal
a few things to ensure
1) battery is fully charged
2) Thed correct BAUD rate and PORT are set ( see manual)
3) You are oiutside and there is a clear view of the sky.
Still failing? Then possible damaged SIIRF chip caused by starting engine while plugged into power socket
Please rate my help++++Thanks for using FIXYA
Jul 12, 2010 | Navman iCN 320 GPS Receiver
Digital TV problems
You are suffering from a poor signal. Digital TVs will display 'blocking' (partial freezing of the picture in square or rectangular blocks) or total freezing of the picture, when the signal is too weak.
You don't say if this is a recent problem on a set that has been working correctly - that info. would be helpful. However, things to check include:
Has the aerial moved (wind?)
Are you using a new extension coax cable? If so try another one, as connections may be faulty.
If this a new TV, and you have not used digital previously, your aerial may not be high enough gain for a digital signal, but that is unlikely unless it's a nery old aerial.
Feb 28, 2010 | Philips TV Tuner Video Capture PCI Card -...
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
I have navman tracker 5500 gps and the gps signal not working so there is no signel but all the charter is there
I HAVE THE SAME PROBLEM.U WILL FIND THE ANTENNA IS BUGGERED.THERE ARE NO SPARE PARTS AVAILABLE FOR THIS MODEL.LESSON; DON'T BUY NAVMAN OR NORTHSTAR.I HAVE ONE OF EACH. NEVER AGAIN!!!
Nov 17, 2009 | Navman Tracker 5500i GPS Receiver
Salelite
does your car have a heat reflective windscreen ?
if it does you will need an external aerial for the gps .
Jul 07, 2008 | Navman iCN 330 GPS Receiver
Icn 520
I have icn520 - bought an external aerial for it off e-bay now get full strength signal evertytime within seconds - well worth about a tenner rather than ditching the 520 which is was about to do!
It was the windscreen causing the problem for me
Jun 07, 2008 | Navman iCN 520 GPS Receiver
Tracker 5600
We had this. Cause was simply a broken aerial cable. Traced by local electrician and re jointed.
Feb 11, 2008 | Navman Tracker 5600 GPS Receiver
NAVMAN GPS Card problems
It is not easy to say what the problem can be. In my opinion you should contact the producer of this GPS receiver and ask them what the problem is. If this has been tested the producer must be able to help the users.
Sep 08, 2005 | Toshiba e750 Pocket PC
GPS Logo
26 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
