Question about Skil Drills
Skil mod.596 type3 1/4" want to chg. to 3/8" chuck. need written dir.
    Top Expert:
  • Skil Master
  • 44,148 Answers
Check YouTube for something similar or contact Skil directly.
Posted on Apr 18, 2017
How do you tighten bit?
Not 100% sure about SKIL cordless, but try turning a collar part just behind the chuck. It may be a friction chuck. Others use a hexagonal female shaft, which has a magnet inside to stop the bit falling out.
Nov 05, 2017 | Skil Drills
The drill chuck is locked and not shifting forward or reverse
Check that there is not a reverse screw in the bottom of the chuck which has become loose. This can jam the chuck, screw it in (anti clockwise) or Spray inside with WD40, then use a large pair of grips to free it in both directions.
May 12, 2012 | Skil 6237-04 3/8 Corded Drill/ Driver
Can't remove the chuck from my Skil Mdl 6237, 3/8" drill. The jaws are locked open as far as they will go and I can't figure out how the chuck is attached to the drill.
Hi
1) check if the chock have a screw fasting it to the arbol if there is one you need to take it out and these crews are left hadle thred
try to fit a pic steel or tool in the chock and tap it hard clock wise then you can take off the screw after tacking off the screw put back the pic steel and tap it hard contra clock wise while holdng the drill and hoppfully it will be out.
Oct 06, 2010 | Skil 6267 04 5.5 Amp Keyless Drill
It's actually a Skil model 4280 sabre saw. Problem is it doesn't grip blades properly, so they are constantly slipping out. Chuck seems to be engaged, have shot WD-40 in it - no change. Ideas?
There is nothing wrong with your Skil 4280. The universal U chuck blade is the problem. Look at Lenox blade 4318JC or Disston 5418 and you will see a slight ridge on the face of the blade on both sides where the teeth start and the blade tail engages the chuck. Without the ridge the blade will come out.
Oct 05, 2010 | Bosch Skil No.4280 - 01Variable Speed Jig...
Have a skil 597 T8 thats lost its grip - is it neccy to change the chuck - and if so can I replace the chuck with one that can open far enough to accept some larger bits?
I couldn't find your particular drill model drill. If this is a corded drill with a 1/4 inch chuck, you would do better to just buy a corded 3/8 drill. But otherwise, yes, change the chuck if you can find one to fit at a reasonable price. Drill chucks are sized to hold a straight bit of the maximum hole diameter that the drill has enough torque to drill into mild steel. If you find a larger one that will fit on your drill, it will work fine, but if you overload it you will burn it out. If you don't drill into steel with any larger bit than the original chuck, then this won't be a problem.
Jun 29, 2010 | Skil 3/8IN DRILL CHUCK/KEY
Skil 3/8 Hammer drill #6425 chuck ring broken in half
get a new chuck - thread is a 3/8-24 left hand thread
Oct 22, 2009 | Skil Drills
Bit or chuck type for a Skil 717 hammer drill
I have a Skill 717, too. It has a hex shank. Here are a couple places that I've located that carry (some) parts:
www.icscuttingtools.com (pages 155 & 157)
www.bamanufacturing.com/page_15.htm
also try:
www.ereplacementparts.com
www.toolpartsdirect.com
Sep 12, 2009 | Skil Drills
I have a very old 3/8'' elecric drill, I think it ia a Skil, The key chuck does not work properly and I want to replace it. How do I remove the old chuck?
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Jun 12, 2009 | Drills
How do I change the chuck on a 5 amp skil drill. It is keyless.
Jun 06, 2009 | Skil 6237 04 5.0 Amp 3/8 Inch Keyless...
Chuck broke on Skil hammer drill
As long as the new chuck threads onto the old spindle then any chuck will work fine.
Dec 19, 2008 | Drills
Drills Logo
79 people viewed this question
Top Skil Drills Experts
epangan29
Are you a Skil Drill Expert? Answer questions, earn points and help others
