The message center isnt working properly its going in and out
Clean your Battery cables and you should see a few body grounds coming off the engine or frame below the front doors. A bad ground will give those symptoms. You also may have a bad contact in your Ignition switch. Clean whatyou can find.
You may have a bad ground under the dash for the lighting. Sometimes it is easier to just add a ground wire of your own than to find the Factory wire. You may be able to find a Diagram for the vehicle, sometimes I go to a Ford Parts counter at a Dealer and the guys will look up the wiring loom and print a picture of it for me.
They are usually pretty helpful and enjoy doing stuff for Customers. After all, if you can't find what is broke, you can't buy parts to replace it.
