Question about Yamaha RX-V863 Receiver
No video from RX-V863
No video signal comes through the HDMI output(just audio).
I have a Mitsubshi HC6500 projector connected to the receiver through the HDMI out and a HD DVR connected to the DVR connection with an HDMI cable.
I get audio but no video. If I plug in the RCA video connector then I can see the menu on the projector, but still no video. On the HDMI setting I get nothing on the projector, even the menu.
  • chris543 Jul 25, 2009
    Reading on the internet, I found a lot of comments about the cable size being a factor so I used a small cable to retest the connection. It still didn't work, but as I was pulling it out I got a signal. So messing about with it I was able to get a signal if I pulled the cable to the left a lot. So I think it is just a bad HDMI connector. Anyone know a good repair shop?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
This reciever might not upconvert component or composite to hdmi, which means if you have anything but hdmi hooked up you will not see it. Check your manual for what all the reciver will ouput.
Posted on Jul 25, 2009
  • Derek Williamson Jul 25, 2009
    In my past dealings with repair shops I have only found that they are crooks. My subgestion would be to run the hdmi directly from the projector to the hd dvr and an just use the reciever for audio only.
I have an RX-V863 and sometimes when I turn the system on with my Harmony remote the receiver continually blinks like it is not getting a good signal and I have to turn the receiver off then back on to get...
Problem seems in standby power supply board and most likely leaky capacitor(s) or cold/ dry solder connections in that circuit board. It is hardware problem and does not look like speaker wires or connection cables fault.
Hope this will help.
Thanks.
Mar 22, 2011 | Yamaha RX-V863 Receiver
I have my cable box hooked up with HDMI and it works great. I have my blu ray player hooked up with components (R,G,B). Im not getting audio or video this way. Can anyone help?
Keep in mind that while HDMI will pass audio with video over one single cable, the Component connectors (RGB) although being 3 cables only passes the video signal, you will also need to connect up a separate connection from your DVD player to you receiver for audio, be it analog (red/white RCA connectors) or optical
Be sure to specify in the DVD's on screen menu which audio output you choose as audio may not pass out all available connections unless enabled. You may also need to select which video output you are using.
As far as not getting video, just be sure you connections are correct (red to red) etc as this would explain the no video...
I hope this helps,
Magoo
Mar 06, 2011 | Yamaha Rx-v365 A/V Home Theater Receiver
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
I have a Yamaha RX-V863 receiver connected to a
Do you have all 5+1 speakers connected? You need to go to the Setup menu of yamaha and set which speakers you have and which you don't. For example if you don't have the Center speaker connected, receiver will redirect and mix the sound to the other speakers.
Blue-ray film over HDMI should automatically output via all your configured speakers (nothing to be configured).
Nov 26, 2009 | Yamaha RX-V863 Receiver
Yamaha reciever doesnt recognise hdmi from Mac laptop
Max does recognize receiver over HDMI-CEC.
The problem is that DVI output is for video only. Macbook won't (and can't) output audio via DVI. So yamaha receives only video signal via the HDMI connector. You can check that by pressing Option button on yamaha remote and choosing Signal Info - you will see info about video, but no audio signal present.
May 22, 2009 | Yamaha RX-V563 Receiver
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
Conecting plasma to receiver using hdmi lead
if you receiver has a Aux function an is still unused try to hook your playstation audio rca up to it directly it will work either way, Hope thats what you mean, An Hope it works
Oct 23, 2008 | Yamaha RX-V863 Receiver
Video Monitor
Check the Setup menu. Goto Video setup and make sure "conversion" is on. Another way to test is to hook up DVD, Cable Box etc. using only the standard "composite" video output (yellow). It should pass thru monitor out regardless of the internal setting on the receiver. Most electronics now are hooked up with Component, HDMI, or DVI which would require the receiver to downconvert the signal in order for you to view it on another video source. Hope this helps. If you still have a problem, list all your equipment model #s and I can troubleshoot more accurately.
Aug 29, 2008 | Yamaha RX-V863 Receiver
Yamaha RX-V863 Receiver Logo
335 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
