G9T06012DHB13D WHAT TONNAGE IS IT - Heating & Cooling
  • David Ellis Rhea Apr 18, 2017
    Hi MICHAEL MCGOWAN, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Try to weigh it, whatever it is.
  • MICHAEL MCGOWAN
    MICHAEL MCGOWAN Apr 18, 2017
    NO IT IS NOT WEIGHT IT IS AIR COND HOW MANY BTU OF AIR WILL IT DO
    Master:
  • 923 Answers
WHAT IS TONNAGE OF BTB730A100A1
12,000 btu/ton. So figure 30÷12 its a 2.5 ton/30,000btu, IF the 30 is the tonnage. Not likely the 100 in the model# is your tonnage unless the a/c is the size of a small house.
Jul 08, 2015 | GE Heating & Cooling
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Apr 07, 2015 | Heating & Cooling
Does the outside compressor tonnage need to be the same tonnage as the airhandler?
when the outside and inside units are both the same size it's referred to as a 'matched' system, which is what 99 percent of all units are.
There are instances when the outside unit is bigger/smaller than the inside unit but as a rule you want the outside and inside units to be the same tonnage.
Aug 05, 2011 | Goodman Heating & Cooling
What is the tonnage on an Intertherm S3RC-0336K.
Hello, the tonnage on this unit is a 3 ton unit. Your model number tells you. The 036 is the tonnage. There are 12,000 btu's per ton, so 36 divided by 3 =12 or in this case 12,000 btu's.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jun 05, 2011 | Intertherm P3RC-036K Air Conditioner
I JUST NEED TO KNOW WHAT MY TONNAGE IS.
Look for your model number on your condensor, outdoor unit. Your tonnage will be towards the end of it and divisable by 6. I.E. 36=3tons or 42=3.5tons. Ac units are messured by the half ton. If you have a split system I.E. heater inside and ac outside your system will be 1 - 5 tons. If this doesn't help post your model and serial number. I can then give you tonnage, age, so forth.
May 16, 2011 | Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
Need to find tonnage of a Luxaire A/c unit serial # ECBM079879...
Get Model number of compressor (all compressors have a tag with a model number on them), and call a dealer who can tell you the tonnage of the compressor which will be the same as the unit.
Note: Write down all the numbers on the compressor to be sure you have the proper info that the dealer will need. Also, you can probably do a 'search' on the computer with the model number of the compressor to find the tonnage.
good luck!
May 03, 2010 | Heating & Cooling
What ton is good man ckl 49 il where is the model number onthe furnace
ok ready for this? To find the tonnage look at the serial # Tonnage is related to 12's If there, on the serial # there is say 0062490 the tonnage is 24 or two tons 24 divided by 12 equals 2 Say the serial # contains 0063090 then the tonnage is 2 1/2 because of the 30 hopefully you see what I am saying the number in the serial # if it can be divided by 12 or 6 this is the tonnage. If you will send me the serial number I will tell you the tonnage. The serial number is on the outside unit at the copper connections where the electrical lines go in.
Good luck on your repairs hope this helped send me a note online here and if you need I will give you tonnage if you send the model # and serial number with your response> I will check online around 1500 hours on 1/9/10 central time. Remember to look for the numbers that are divisible by either 12 or 6 on the serial number
Dave
Jan 08, 2010 | Goodman CKL60AR60 Air Conditioner
Need to verify tonnage of unit
In almost every case, most manufacturers put the tonnage in the model number. Look for something that is divisible by either 6 or 12. Something like, 24, 30, 36, and so on. Cfm has to match the tonnage. Usually in the neighborhood of 450 cfm per 12,000 btu's of cooling for the inside of the structure.
Hope this helps.
May 08, 2009 | Heating & Cooling
CAN' READ PLATE ON A/C - CAN'T TELL TONNAGE
that comp is a 25k btu depending on the age of the unit it is a 2 ton or 2 1/2
Aug 10, 2008 | Ruud UAKA030 Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
