SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
SOURCE: Error display "CL" - what to do?
THe child lock is on. Mine came on for some random reason. On my LG front loader there is a button on the right hand side with a cartoony picture of a child and a padlock. Press this.
SOURCE: LG Washer Issue - can you please help
Generally, this happens when the washer was pushed back into place by applying force to the front of the machine, thus pushing the front panel in just slightly. Sometimes you can fix this by just moving the location of the spring of the front gasket clamp from the bottom center to the left side hinge area. They actually make a special tool for expanding the spring, but you can manage without the special tool. Other times you may have to pull the front panel a out a bit or possibly replace the gray gasket / seal.
SOURCE: lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
