Question about Electrical Supplies
My ACE-75LP can not produce more than 25PSIG is there an adjustment?? do I need a new impeller??
Repair power ace 150 pool pump
remember !!!! left hand threads are present on most impellers if not they'd unscrew right off shaft when motor started (Cw)
also id personnely never just change an inpeller with at min installing a new pump seal and sometimes bearings too , I just dont like doing things twice !!
Oct 19, 2014 | Pool & Spa
96 accord is running real hot. New radiator, both fans are working-just replaced the condenser fan and themostat (Honda thermostat) coolant been replace. I can drive it ( 20 to 140 miles and it will get to...
water pump impeller i think here is the problem ,theyr use a plastic impeller on a metal shaft and after a while they spin on the shaft so the force needed to turn the impeller is passed on to the impeller it just stays still causing the exact symptoms you describe
Sep 15, 2011 | 1996 Honda Accord
My jet pump has a 20 - 40 pressure switch but won't give any more than 30 psi. Whats wrong?
There are several causes for this to occur.
1. If it is a 20-40 switch right out of the box it may not be set correctly. I have had this happen. If it builds to 30psi and shuts right off without straining to build to 40psi adjust the Cut-Out pressure up to 40psi. There are two different adjustments on a well switch. One for Cut In / Cut Out psi and one for Cut Out psi.
2. Lack of head pressure being built by the pump can be the cause. This can be attributed to the wrong Jetting in the pump. IE: A shallow well jet/venturi on a deep well.
3. The pump may have a bad impeller, but the pump will generally really strain to build pressure and a bad impeller will be loud, like grinding at times.
4. Double check the pre-set pressure in bladder tank also.
RJ
May 28, 2011 | Fairbanks Ace 1 Horsepower Convertible...
My Ace 2000 is very loud, like their is a fork in
Jim,
You are exactly right. Knife, spoon, fork , whatever. that metal on metal sound is produced in the flail chamber.
Get a flashlight and have a look inside.
Needle nose pliers can be handy for extraction.
Mike
May 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My 2002 750 ace keeps backfire when I rev it up
did you change the exhaust and air filter? if not, you should. bike is running rich. lean it out a little and you'll be alright.
May 04, 2010 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Should I adjust my valves? 1999 Honda Shadow Ace.
Well if its running good and you don't here any out of the ordinary rattling I wouldn't worry about it until at least 25,000-30,000 miles on the bike so probabley in another 10,000 miles or so have the valves adjusted unless you hear any unordinary rattling noises sooner then go in at that point and have them adjusted.
Apr 21, 2010 | 1999 Honda VT 750 CD Shadow A.C.E. Deluxe
I have a 1 hp ace pump on a 30 gallon bladder tank the pressure switch keeps clicking off and on until the switch burns up have replaced 4 times in 2 months have adjusted switch until pressure is very low...
There are tow screw adjustments on the switch. One is the high shut off and the other is 'differential'. This is the one you need to adjust. It gives the 'window' that the system needs 'between' on and off.
Aug 30, 2009 | ACE JET PUMP For shallow well
Motor hums, but propeller will not turn
I HAVE A ZOELLER PUMP AND THE IMPELLER WONT TURN I TAKE A SCREW DRIVER AND TURN IT AND IT WORKS STOP THE PUMP AND IT HUMS CAN THE IMPELLER COME OFF IF IT DOES HOW DO YOU TAKE IT OFF.
May 06, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
