Question about Samsung Washing Machines
I have an we356a5c/xaa Samsung front loader washing machine. I can't find any screws to remo
  • Samsung Master
  • 923 Answers
Here is a helpful link for you!
Posted on Apr 18, 2017
Samsung WF317aag-xaa front loader will not drain. I have replaced the pump motor and the PCB. When I put the machine to spin the door locks and I hear two click and then nothing. display ND again.
Have you check with a multimeter to see if you have 120volts to the pump? If so you may have a clogg in the hose that goes from the tub to the pump. I've seen it before.
Jul 01, 2017 | Samsung Washing Machines
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ... > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
I have a Samsung washer front loader it vibrates really bad when it is on spin cycle model #wf409anw/xaa
To test whether the problem is caused by a fault in the machine, or the way it's being used, run it through a complete empty cycle. No clothes, no detergent.
If it still vibrates under those conditions, call a repairman. If not, then the cause is an unbalanced load. This often happens when dis-similar weight articles are placed in the washer at the same time - such as bath towels along with tee shirts, etc.
Dec 12, 2014 | Samsung Washing Machines
Is samsung pedestal model number WE356A5W/XAA compatible with samsung front loader washer wf220anw?
The correct pedestal for the WF220ANW washer is WE357A7W . The WE356A5W is a slightly different size to secure it to the washer (14 2/5 X 27 X 28 7/10 In). The WE357A7W is 27"(W) x 14"(H) x 28.5"(D). The holes for the screws will also not quite line up.
I hope this helps.
Jul 11, 2011 | Washing Machines
I have a Samsung Front Loader Model No WF316BAW/Xaa and it is so load and shakes all over the floor. What might be the problem?
The first thing I would check is that the unit has been leveled. Adjust the washer feet until the unit is level. NOTE: Check the feet and make sure they are operational before starting a level procedure.
Jun 08, 2011 | Samsung Washing Machines
How do I replace the oring gasket on a front loading samsung wash machine model number wf219anw/xaa
I can tell you how to fix one on the WF218ANW/XAA washer. Your model may be the same. You need to take the top panel off the washer by taking out two screws on back panel. You need to remove the control panel and place it on the top of the unit (it is attached with electrical cord). You need to talk out the detergent tray (press the clip in the middle). You then take off the front panel. it is not necessary to take off the door; however, to remove the panel you will need to remove the door latch mechanism on the inside of the door. To remove front panel, there are also two screws on the bottom of the unit. Once you have the front panel off, remove the old gasket by loosening the two springs rings. Pay attention to how the gasket is installed before removing. Replace gasket by installing inner portion first and replacing spring ring and tightening. Put all the parts back on the washer and install the outer portion of the gasket (with the spring ring). Samsung charges $130 to do this in my area and it's a pain in the neck.
Aug 11, 2010 | Samsung WF337AA Front Load Washer
Replace belt j845 samsung front loader washing machine. how do i get replacement belt on as back and both sides of machine is one piece of metal
There is no belt on a front loader washing machine. The way the drum spins is by a stator in the back of the unit.
Dec 29, 2009 | Samsung WF337AA Front Load Washer
Need to take case off dryer there is something stuck inside because kids dried with lint screen out
Apr 29, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Washing Machines Logo
43 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
