On the touch panel for my Model WC220, the green light when on the "On" mode is not light up; therefore, neither the fan or light on the fan will turn on. Can you help me with that?
2 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: GE model JVM5503 (1980): light and exhaust fan
That would be a problem with your "touch control" but it is no longer available.
The oven will have to be replaced.
Sounds like it had a good run.
Posted on Jan 16, 2010
Why does my sanyo model KHS2472 has a red light blinking in heat mode and a green in cooling mode, does not work in either mode makes a gurgling sound when it tries to run?
The red light indicates it's either heating or in defrost mode
Check the outdoor unit if the compressor is running - the large pipe on the outdoor unit should be hot on heating or cool to touch on cooling
When in heating mode - the indoor fan will not start until the indoor coil is warm enough
If the reversing valve that changes from heating to cooling is faulty then you may encounter the same symptoms too
Probably need a Refrig Tech to have a look at it?
Good luck
Jan 07, 2016 | Sanyo 24KS72 Split System Air Conditioner
What is the red light on my wd-60737 mean?
You can Google the brand and model number for a free owner manual but on the set indicated it means usually the lamp is the issue.
Mar 27, 2012 | Mitsubishi WD-60737 60 in. HDTV
Ge Artica Refrigerator PSC23PSTA ss not cooling or freezing. Refrigerator reading 45 and freezer reading 6.
Typical problems that can cause this:
- iced up evaporator due to defrost problem
- failed thermistor (temperature sensor)
- compressor not running
all of the above could be due to a failure in the main control board
there is a diagnostic mode that can help you diagnose cause
Jun 15, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE model JVM5503 (1980): light and exhaust fan work, but touch pad does not respond to pressing buttons and therefore no functions can be initiated.
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
When we turn on our split AC, outside unit is not turning ON
The blinking light is because the unit is waiting for the outdoor unit to come on. If in heating mode, the indoor fan will not run before enough pressure and therefore heat has built up. You should check that the indoor air return sensor is not faulty and therefore preventing the outdoor unit from coming on.
Nov 15, 2009 | Amcor NanoMax A12000E Portable Air...
Monitor problems
It seems that you are trying to use a graphic mode that your monitor doesn't support.
Restart windows in safe mode, go to Control Panel. Click on Display. Select settings and change to a resolution that is supported by your monitor (I don't know your model, but 1024x768 is a safe bet).
Restart the computer.
It should be working by now.
Dec 21, 2008 | Relisys RLT1720 17" LCD Monitor
It does not turn on, remains in stand by mode.
I cannot be COMPLETELY sure of this so be careful, but doesn't the PS3's board cater for both types of power supply and therefore a step down transformer is not needed? Check the labels on it just in case, but be wary I CANNOT be certain of this...
Aug 22, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
