Question about Microwave Ovens
Where can I buy magnetron for cusinamart microwave oven
  • Microwave Ovens Master
  • 3,282 Answers
Dear Pastor,
Type Cusinart (sp.) into your search engine on your computer and see if a dealer or distributor, or even a factory shows up.
Ask them.
I tried to do this for you, had no results.
Understand that Cusinart is a label that is stuck on microwaves in the factory of whoever is making microwaves, therefore your magnetron should fit many other machines.
God bless your efforts.
Posted on Apr 18, 2017
    Prodigy:
    An expert who has answered 500 questions.
  • Microwave Ovens Expert
  • 547 Answers
The magnetron usually has a type number on it. It may start with "2M" or may be entirely different. All you need to do is order the same type. Some sell for as little as $20.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Posted on Apr 22, 2017
NO HEAT
Most likely a bad magnetron. Not something for a do-it-yourselfer to fix. Call a repairman or buy a new microwave. Magnetron replacement will be expensive.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Aug 08, 2014 | GE Spacemaker JVM1540 Microwave Oven
Microwave has quit heating. everything else is working.
The problem is most likely caused by the magnetron, and there are two other parts that can be a factor, the high voltage capacitor and diode. The above mentioned work together to heat food, if the magnetron is gone you would be further ahead buying a new microwave oven
Mar 10, 2011 | Samsung MW1150WA Microwave Oven
MAGNETRON HAS FAILED.... I have the "over the stove mounted version" . What microwave will fit perfectly in that same space over my stove?
I would source a magnetron from ebay and fit it. Got to be cheaper than buying a new one and you know how it works!
Mar 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Made noise and now does not heat food some lite spoke came out the top vent. Microwave has power everything turns on but does not heat the food.
Your oven almost certainly needs a new magnetron tube, the microwave source. One of the ways they go bad is to short out, and that's sometimes followed by a smell or smoke. The magnetron can be replaced, but it's the most expensive part in the oven. It may be more economical to buy a new oven than to repair one with a bad magnetron. The repair should be done by a professional because of safety concerns, and between labor and the part cost, the total repair may actually exceed the price of a new oven.
There are other things that can go wrong, but the magnetron is the most common. If you want to keep this oven, let a qualified appliance technician check it over and give an estimate. Then decide whether to repair or replace it.
Dec 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
All features of oven work normally but there is no heat and nothing cooks. What is causing this?
Mostlikely the magnetron circuit has failed. The magnetron is the part the makes the microwaves that heat the food. It can be pricely to repair and if the magnetron needs to be replaced, the cost of replacement typically is about the same as buying a new oven. Sorry.
Dec 06, 2010 | GE Profile Spacemaker JVM1871 Microwave...
Everything works but it doesn't heat up the food. What could it be?
The part that generates microwaves that heat the food is the magnetron. Typically when the magnetron fails, it shorts out. When that happens the oven will produce a loud buzzing or humming sound. It typically not worth the cost to replace the magnetron, because it is almost as much as buying a new oven.
Jul 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I believe the magnetron just went out
Make a few phone calls and get the actual costs-then decide. You cant normally fix microwave ovens yourself though. Generally when the magnetron goes its time to buy a new micro unless its under warranty.
Oct 03, 2009 | GE JVM1410 Microwave Oven
MY MICROWAVE DOEST HEAT, IT LOOKS LIKE WORK NORMALY BUT DOESN HEAT
pull your magnetron connector out and clean the both pins with alcohols or a metal cleaner and then fix it again and use. magnetron will work surely.
Oct 03, 2009 | Samsung MW8574W Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
