Question about Baby Gear
Model LAD504DUL recall? - Baby Gear
Is there a recall on model LAD504DUL
Yes, the recall of Midea-manufactured dehumidifiers includes some models of the LAD504DUL. Go to https://www.recallrtr.com/dehumidifier. Use the drop-down menus to select the make and model. Then, enter the serial number of your unit to check if that particular unit is one of the recalled dehumidifiers.
I hope this helps.
Feb 10, 2017 | Baby Gear
WILL TURN OVER BUT WILL NOT START
There are 2 possibilities: the spark plugs are not firing or the fuel system is clogged.
There are 2 ignition switch recalls for your vehicle:
Check your vehicle for the recall service stickers or call BMW and have your VIN number ready when you call and have them run your vehicle service history.
They should be able to tell you if the recall had been performed on your car.
Recall ID # 93253 - ELECTRICAL SYSTEM:IGNITION:SWITCH plus.gif Full Details Recall Date OCT 17, 2012 Component ELECTRICAL SYSTEM:IGNITION:SWITCH Model Affected 7-Series Potential Units Affected Recall ID # 93244 - ELECTRICAL SYSTEM:IGNITION:SWITCH plus.gif Full Details Recall Date OCT 17, 2012 Component ELECTRICAL SYSTEM:IGNITION:SWITCH Model Affected 7-Series Potential Units Affected
Read more: http://www.motortrend.com/cars/2007/bmw/7_series/recalls/#ixzz3Ft0kI54g
Oct 11, 2014 | 2007 BMW 750Li Sedan
Was there a recall for evenflo Embrace model number 4851928A
Although there was a recall on Evenflo Embrace models: http://www.cpsc.gov/en/Recalls/2007/Fall-Hazard-Prompts-NHTSA-CPSC-and-Evenflo-to-Announce-Recall-of-Embrace-Infant-Car-SeatCarriers/
The model number you listed does not appear in the list of those recalled.
You can read the info provided in the link for further information about the recall.
Aug 29, 2012 | Baby Gear
Is this a recall item. Hss25gfpd ww Model
No recall on this model as of this time.
Aug 28, 2009 | Refrigerators
Has model # 012616 been recalled?
As far as my research the jenny lind model 012616 has not been recalled but you should log onto the consumer safety website at www.CPSC.gov and check to make sure, this is a great website to check out consumer safety and recalls.
Aug 27, 2009 | Evenflo Jenny Lind Crib
Is this GE Profile dishwasher recalled?
No recalls on any GE Profile model dishwashers. (there may have been service bulletins, but no recalls) Also, you missed the first two letters of the serial number.
You can go to this web site http://www.geappliances.com/products/recall/ to find info on any GE recall.
May 07, 2009 | GE 25 in. PDW7380JSS Stainless Steel...
I hear you recall for maintenance(ice maker problem)
We don't recall anything here, we're here to help. Product recalls are from the manufacturer. You haven't listed a make and model of the refrigerator, so I can't help more than to tell you to go to the manufacturer's website. If there are any product recalls affecting your model, that information should be available on their site.
Apr 27, 2009 | Refrigerators
IS THERE A RECALL ON JENN-AIR REFRIGERATOR, MODEL #JCD2389GE ?
MAYBE!  Our Jenn-Air side by side has a similar model number to yours and it was recalled on March 10.  Check on maytag's recall page to see if your fridge has been recalled by entering your model and serial number.
Mar 11, 2009 | Jenn-Air JCD2389G Side by Side...
Odometer,speedometer,etc. (not the lights) goes out on dashboard
Here are the Recalls for your Model Car. Nissan Altima Recalls Recall ID # 07E087000 - EXTERIOR LIGHTING:HEADLIGHTS Recall Date: OCT 25, 2007 Component: EXTERIOR LIGHTING:HEADLIGHTS Model Affected: ALTIMA Units Affected: 4654 Recall Details Recall Date:OCT 25, 2007
Model Affected:2006 NISSAN ALTIMA
Summary:CERTAIN TYC HALOGEN TYPE HEADLAMP ASSEMBLIES P/N 20-6644-00 SOLD AS AFTERMARKET EQUIPMENT FOR 2005-2006 NISSAN ALTIMA PASSENGER VEHICLES. THE PHOTOMETRIC WERE MISALIGNED WHICH DOES NOT COMPLY WITH FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.
Consequence:MISALIGNMENT OF THE LIGHTS DIMINISHES FRONTAL ILLUMINATION WHICH COULD RESULT IN A VEHICLE CRASH.
Remedy:GENERA WILL NOTIFY OWNERS AND OFFER TO REPURCHASE THE NONCOMPLIANT LAMPS. THE RECALL BEGAN ON OCTOBER 25, 2007. OWNERS CAN CONTACT GENERA AT 714-522-6688.
Units Affected:4654
Notes:GENERA CORPORATION Recall ID # 06V223000 - ENGINE AND ENGINE COOLING Recall Date: JUN 21, 2006 Component: ENGINE AND ENGINE COOLING Model Affected: ALTIMA Units Affected: 85000 Recall Details Recall Date:JUN 21, 2006
Summary:CERTAIN PASSENGER VEHICLES EQUIPPED WITH 2.5L ENGINES MAY EXPERIENCE EXCESSIVE ENGINE OIL CONSUMPTION AS A RESULT OF IMPROPER PERFORMANCE OF THE PISTON RINGS.
Consequence:IF THE OIL IS NOT MAINTAINED AT LEAST AT THE MINIMUM LEVEL, ENGINE DAMAGE CAN OCCUR AND IN EXTREME CASES RESULT IN AN ENGINE FIRE.
Remedy:DEALERS WILL REPROGRAM THE ELECTRONIC CONTROL MODULE (ECM OR ENGINE COMPUTER). YOUR VEHICLE WILL ALSO BE INSPECTED TO DETERMINE IF IT HAS BEEN CONSUMING ENGINE OIL AT A HIGHER THAN NORMAL RATE. IN A SMALL PERCENTAGE OF VEHICLES, ENGINE REPLACEMENT WILL BE NEEDED. ON JUNE 9, 2006, NISSAN NOTIFIED OWNERS OF THE POSSIBILITY OF EXCESSIVE OIL CONSUMPTION AND THE IMPORTANCE OF MAINTAINING THE OIL AT A PROPER LEVEL. FOLLOW-UP LETTER TO OWNERS ADVISING THEM OF THE STATUS OF THE RECALL WAS SENT DURING AUGUST 2006. FOLLOWUP LETTER TO OWNERS WAS SENT ON NOVEMBER 15, 2006. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Units Affected:85000
Notes:NISSAN NORTH AMERICA, INC. Recall ID # 06V046000 - SUSPENSION:REAR Recall Date: FEB 13, 2006 Component: SUSPENSION:REAR Model Affected: ALTIMA Units Affected: 759 Recall Details Recall Date:FEB 13, 2006
Summary:ON CERTAIN VEHICLES, THE REAR SUBFRAME MAY HAVE BEEN MANUFACTURED INCORRECTLY, WHICH COULD RESULT IN A CRACK IN A BRACKET WHICH HOLDS PART OF THE REAR SUSPENSION.
Consequence:IF THE BRACKET IS CRACKED, THE STABILITY OF THE VEHICLE MAY BE AFFECTED UNDER SEVERE DRIVING CONDITIONS. THIS COULD LEAD TO A LOSS OF CONTROL OF THE VEHICLE WHICH COULD RESULT IN A CRASH.
Remedy:DEALERS WILL INSPECT THE REAR SUBFRAME TO DETERMINE IF IT WAS MANUFACTURED INCORRECTLY AND REPLACE IT, IF NECESSARY. THE RECALL BEGAN ON FEBRUARY 27, 2006. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Units Affected:759
Notes:NISSAN NORTH AMERICA, INC. PB016 Recall ID # 07V527000 - ENGINE AND ENGINE COOLING Recall Date: NOV 14, 2007 Component: ENGINE AND ENGINE COOLING Model Affected: ALTIMA Units Affected: 653910 Recall Details
Jan 03, 2009 | 2006 Nissan Altima
Recall
just go ton google search type in your model # and it will bring you to arizona salvage which lists a;; recalls. Also lists 1-800-#
Sep 08, 2008 | Dometic RM2652 Refrigerator
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
