Question about Microwave Ovens
Cusinamart micro wave oven does not heat when starting
MicrowaveSvc
  • 9047 Answers
SOURCE: Ge jvm1860 microwave oven
Rotu is right - it certainly could be crud on the waveguide vcover or waveguide. If not, it might very well be be a bad magnetron. My understanding is that GE had a run of bad magnetrons and/or other problems in the high voltage section, but I don't know if they publicly acknowledged it. If it's not a dirty waveguide problem, I would contact GE or an authorized servicer. If you don't have a manual, you can download it here: http://www.geappliances.com/service_and_support/literature/
Posted on Oct 18, 2006
SOURCE: micro wave oven doesn't heat
replace magnetron
g.k.mahendran
contact www.microwaveovengkm.com
Posted on Jul 24, 2008
  • 583 Answers
SOURCE: boiling waer under micro wave lots of steam into
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Posted on Mar 03, 2009
wiznet2000
  • 86 Answers
SOURCE: micro wave wont heat up food.. i think its the
Replace the HV capacitor
Posted on Sep 13, 2009
  • 49 Answers
SOURCE: I have a built in Whirlpool Micro Wave oven that quit
if you open the cupboard door above the microwave you should see two or four screws/bolts holding the microwave up there. there should also be an electrical outlet up there where the microwave is plugged in. have at least two strong people. put some blankets on your stove top to protect it. unplug and remove the screws. it should be connected in back by a metal plate also. when the microwave is tilted down at a fourty five degree angle, you can give a little lift and it should pop off the plate in back. it is heavy. get a new one at sears or other appliance retail outlets. i dont recommend best buy. they really screwed me over so i dont send business their way.
Posted on Oct 20, 2009
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
Micro wave will not heat has a picture of a little micro wave on the screen
Either the power board to supply the magnatron or the magnatron is defective.
Check or have someonr check the output of power supply. If ther is a hi reading, then change magnatron
Aug 05, 2010 | General Electric Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave stopped heating. All other features
Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Mar 03, 2009 | Amana Radarange Microwave Oven
Microwave comes on but doesn't heat ge.jvm1540
In the case of microwave ovens, the commonly used radio wave frequency is roughly 2,500 megahertz (2.5 gigahertz). Radio waves in this frequency range have an interesting property: they are absorbed by water, fats and sugars. When they are absorbed they are converted directly into atomic motion -- heat
So, NO Micro waves NO heat......... Need to check for Microwave emitter device installed inside.
Sep 11, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
