Question about Dishwashers
Does the bottom pop off for cleaning? - Dishwashers
While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
Jan 18, 2017 | Ovens
Cleaners at bottom of pool dont pop up
Filter could be dirty?, clean or backwash.
or... You could have some debris: sand, grit, pebbles, etc. in your separate rotor valve assembly. There are small gears in there that turn the rotor plate, it allows for water to enter each set of pipes in a certain timed cycle. If those gears don't turn correctly, water won't flow alternately into those pipes that lead to each pop up head.
Apr 11, 2014 | Paramount Cyclean Automatic In-Floor Pool...
Getting popping noise from water heater after shower
Popping sound is caused by sediment built up in bottom of tank: air bubbles get trapped when heating starts, and then they crackle, rumble etc when free.
Clean out sediment:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/pdf/How-to-descale-water-heater.pdf
The steps vary by type of water heater, gas or electric
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 27, 2013 | Water Heaters
We cleaned our bottom oven. Now when you turn the
Hi it wouldsound like the is a short causing it to trip did you get any thing wet
Jan 19, 2010 | Maytag MER6772 Gemini Electric Kitchen...
How do i clean my tower aloha breeze fan
you have to remove the fan housing. it is usually screwed.
Sep 10, 2009 | Tower Aloha Breeze Fan
WATER POOLIN AND FREEZING AT ON FLOOR OF FREEZER. ICE MAKER NOT HOOKED UP
you have a blocked drain remove back freezer panel
at the bottom you will find a lot off ice remove it with hot water and clean drain hole the pop is the ice cracking
Apr 17, 2009 | Refrigerators
LG Refrigerator GR-642AP need to remove water dispenser
i have the same fridge there are 2 screws down the bottom one is behind a round plastik cap you have to pop out the the top has 3 screws that is it not that hard then it pops off unplug power cable plug and clean to your hearts content. mine wasnt pumping water out the inside hose popped off  easy fix it took me 3 years to get around to fixing it today
Feb 01, 2009 | Refrigerators
Popping sound with picture
try getting a cleaning kit from radio shack for 15 bux the lens maybe dirty
Jan 21, 2009 | Haier TN201AUV 20" TV
How to take apart the diswasher to clean it
This is a 5 step process.
1 Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports).
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly out.
3. Remove overhear conduit. There is one screw at the back and one at the top (Philips #2 bit). Rotate the whole assembly 45 deg right (Clockwise) and lift off of the centre post. It can be taken apart to clean.
4.Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift the whole plastic assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at the front left (Under center assembly just removed). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter & filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc up. Clean thoroughly. Run a 'quick rinse' cycle with everything out, to clean the inside.
Reassemble.
Jan 01, 2009 | Kenmore 15129 Built-in Dishwasher
How do I remove the grate on the bottom to clean the coils
They are usually held in with clips that snap in and out. This is especially true if you don't see any visible screws. Give it a good tug on one side and see if it pops out.
Dec 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dishwashers Logo
Top Dishwashers Experts
