Question about JVC Televison & Video
I purchased a JVC LT52X579 March 30/09. The TV would phase out by itself and then restart by itself. Some times it would remain on and could be cut off only by unplugging it from my sudge protection unit. Aaron'S sale and Lease (retailer) exchanged this set for another set (same model & make). I had the exchanged set for a few weeks and then experienced an area power shutdown. All electric applainces in my home went out for a few hours. After the outage I pushed the off power switch on my TV...to insure that the TV would remain off if the power was restored while I was away or sleep. All power was restored a few hours later, but the TV would not come on. All other appliances, lights, video player, Direct TV Receiver were on, but my 52 inch TV remains dark. can you diagnose this problem?
  • 585 Answers
So from what you say the flat LCD JVC TV has a main power switch that you turned off and after power was restored you turned on the main power and also the other power switch (or remote on) and nothing lights up at all, not even the power light. Sounds like the power going off may have blown the internal fuse, or damaged the power supply.
you can open the back and see the power supply which has a wire running from where the AC goes in, check or replace the fuse located near the AC wire. if the fuse is good do a visual or the board for capacitors that look swollen or exploded. they can be replaced.
if good fuses and caps, then you need to measure for 5volts , best place if its not makred on the board is on the remote reciever sensor.
If 5 volts is there the power supply is probably Ok and the other board (signal board) is bad. there are only two main boards in most LCDs.
Hopefully its something simple like the main switch is have on or a blown fuse.
the circuit boards cost about $350 each, if the TV is under 1 year old you can get it fixed under warranty.
Good luck
Eric
Posted on Aug 22, 2009
  • 10,594 Answers
Please unplug TV from wall socket for couple of minutes, replug back in and turn ON.
If still does not power up, try it in another wall socket.
Also check standby/ power light flashing or its solid at TV.
If standby light is flashing or its not lit then TV got power supply problem and requires qualified TV tech. I hope TV is still under warranty so ask for warranty cover to store.
Thanks.
Posted on Jul 24, 2009
Where can I get a copy of the moon phases for February 2015.
Here is February since you asked specifically for it. The next link is for March.
Moon Phases February 2015
Moon Phases March 2015
Mar 02, 2015 | Watches
Jvc 32
What is the exact model of your TV?
Apr 19, 2008 | Televison & Video
Power supply board
There is no one that handles that part that I can find.
Sep 30, 2013 | JVC Lt-32p510 32" Lcd Tv
JVC 42" Tv has cut off and when it came back on
If using a cable box try connection direct without the box---also try to remove power from set and box for a while and then power back.
Dec 03, 2012 | Televison & Video
JVC MV-P612U Professional Microphone Wiring to XLR
The MV-P162U is a stereo mic designed to plug into a JVC professional camcorder. dates from the 1990's and was very expensive.If the 6 pin plug has not been cut off, and you can get a socket to fit, then going clockwise around pins (or wiring side of socket) from the locator.
1) R phase +
2) +8V supply
3) -ve supply/gnd
4) L phase +
5) L phase -
6) R phase -
suggest a small breakout box. tested it with a 9v battery - the drain is 14ma. could run from 12v via a 285 ohm (approx) resistor with a 47uf cap across the mic supply.
Apr 15, 2011 | JVC MV-P612U Professional Microphone
Is a dual XLR adapter available for the MV-P612U JVC stereo mic.
1) R phase +
2) +8V supply
3) -ve supply/gnd
4) L phase +
5) L phase -
6) R phase -
May 05, 2010 | JVC MV-P612U Professional Microphone
My JVC AV-48WP30 picture is distorted vertically to about half the screen height. If I turn the tv on and off a few times, sometimes it will correct itself, until I turn it off again.
Try resoldering the vertical output IC that should correct the issue repeated off and on cycles often tend to bridge the solder connection causeing the set to work untill power is cut off.
May 15, 2008 | JVC Televison & Video
JVC AV-28GT1SJF
you have to get into the tv to do the adjustment. take the cover off and then look for the CRT tube and follow the yoke cables that will lead you to the printed circuit. you should see some small tiny knobs there. something like vertical phase or horizantl Phase..you need the verital to adjust the vertical size of the pic..good luck
Feb 24, 2007 | JVC AV-28-BD-5-Bl 28" TV
Televison & Video Logo
120 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
