Question about LG Washing Machines
LG WF-T8014HN top load machine DE error during wash
  • 42 Answers
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive. for more info.
Posted on Dec 15, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
I have a LG topload intellowash WF-T7516LS as soon as i switch on the machine the water fills in and then it just shows dE pls help
dE stands for Door open Error. Your door is not closed properly or the door switch is not activated. Try to press the door firmly. If the error does not go then you will have to check the door latch, notch ( a protruding part which goes inside to latch & activate door switch) & the door switch for any damage. For Top load machines the notch is near the hinges & inside the machine.
Sep 22, 2011 | LG WM-2277HW Front Load Washer
I own an LG WF-TS728PC washing machine top loading. Recently i keep having this problen "dE" error and the manual book says its something to do with the door. I've tried shutting the door close...
The de error is a door switch error or main board error.
Try unplugging the machine for 3 min and see if it will reset.If not you will need to have the machine serviced.
Apr 15, 2011 | Washing Machines
LG Top Load Washing Machine Model: WF-T7517TE , kg TURBO DELUXE. On Pushing START button , MAchine just starts and stops after a second. Message displays "dE". What to do ?
'de' on LG's stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 20, 2011 | LG Washing Machines
I have problem with lg wf-t507 top loaded washing machine when i start it work for few seconds and than show DE .
'DE' on an LG normally stands for 'door error'. It is possible that the door catch/sensor either requires adjustment, if that is possible on your particular machine, or will require replacement.
Sorry but you will need to call your local service engineer ;-0(
Good luck,
John C
Feb 27, 2011 | Washing Machines
My lg WF-T552TH washing machine will not drain the water during a cycle just wondering how i can fix it??
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Oct 25, 2010 | LG WFT1071TP Top Load Washer
I have lg top loader washing machine model wf583spc if i start any program after 30sec the De error blinking please give the guide line also drain clear & door ok but always show same problem
Aug 17, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine
buy a new washer,the spider gear is gone probably from to much detergent,it's around 500 bucks for the part
Feb 11, 2010 | LG WM-2277HW Front Load Washer
Washing Machines Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
