Question about Vacuums
While cleaning, noise suddenly changed (louder, slightly higher). Very little 'suck' to the floor pad and very little to the free wand when the cleaner is in the upright position. Can you advise?
I have a ball model. HR6-UK-GCA3725A. (Not sure whether that is a model No or a serial number.) (Cleaner about 2 years old.) The cleaner glides over the floor, rather than being pulled down onto it by the vacuum.
    Habit-Forming:
  • 100 Answers
From your description, there is definitely a blockage somewhere...
Check all the pipes and tubes thoroughly.
Posted on Apr 18, 2017
Dc 14 does not suck very well when on carpets massive suction through wand
Hi Diane, it's Jack at Dyson.
If your DC14 isn't picking up well on carpets despite having strong suction through the wand, there are some simple troubleshooting checks you can run through. I understand you've checked for blockages and washed the filter, but there may be something you've overlooked. These checks will help you determine if there's a blockage or another issue that may be causing this: http://www.dyson.co.uk/support/dc14/dc14-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/no/loss-of-performance
If you'd like further advice after giving each of these diagnostic checks a try, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jan 18, 2015 | Dyson DC14 All Floors Upright Vacuum...
Pulsing then stops
Hi there, it's Jack at Dyson.
Dyson Digital Slim cordless vacuums such as DC44 Animal are engineered to make a pulsing noise to warn you if the machine has a blockage. This can occur if an item too large for the machine has been vacuumed up accidentally. It's easily resolved by checking the floor tool, wand and bin inlet: http://www.dyson.co.uk/support/dc44/dc44-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual-dc44/no-resolved-redirect-to-check-the-wand/check-wand
I'm confident following these steps will resolve the issue, but for any further guidance from our experts you can reach us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 06, 2014 | Dyson DC44 Animal Handheld Vacuum Cleaner
My Hoover windtunnel has very little suction. I have cleaned the entire vacuum. Cleaned filters. My Hepa filter is a little torn, don't know if that could be issue. After cleaning it does suck a tad bit...
Is the belt still intact?
Does it has a wand tool, normally they are connected at the bottom of the machine,if it gets plugged up with gunk, that will greatly reduce your suction.
Aug 31, 2013 | Hoover WindTunnel Purely Pet Vacuum...
Hi. My dyson dc14 wand works great then all of a sudden if something too big or even just the carpet it makes a sucking noise & the purple round bit in the actual Hoover makes a funny noise & then...
Sounds like a blockage. I have a DC14 and I have never had this problem. You can easily remove the wand from the flexible hose and the flexible hose from the machine to check for a blockage. Don't allow paper or larger items to go into the machine, especially the wand, pick it up by hand first. Find the online manual here: http://www.analogstereo.com/dyson_vacuum_owners_manual.htm
May 03, 2013 | Vacuums
No suction
Sucked up a sock?? No seriously.. it may be as simple as that or that an on board filter is clogged. Check your manual for all filters and Hepa/screens and others. Also, is the unit making any odd noises since the non -suction scenario? Whining or screeching sounds, where is the motor impeller/vac bearing or similar is damaged or a hose is kinked within hte unit itself.. <not normally unless the unit has been taken apart and placed back together and crushed the main return vac hose. .
Apr 30, 2010 | Dyson DC14 All floors Bagless Upright...
My AirVac 3000 stopped working while I was vacumming. The motor runs but it is not sucking. The bag was changed. The panel circuit breaker had not tripped. What could be the problem? Thanks.
You may have a clog in the hose or wand assembley of your accessory kit. Remove the both wands from the accessory and check your suction. If you have suction there the clog is in the wand or the tool you use to clean the floor. If not you have a clog in the hose itself.
Apr 16, 2010 | M&S Systems FX-3000 Bagged Central System...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Hoover steam cleaner F5805 no manual
the plastic wand helps, but I have found that when I pick the entire unit up and take it to the sink and run water in the top of the plastic cover it cleans it out better than anything. I get alot of pet hair up also and it looks awful -- but the wand only cleans out the hair -- the dirt needs to be flushed out some time too
Jul 04, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Rainbow e series vaccum/scubber
If you are talking about the hard wood floor brush you hook it at the end of the one slightly bent wand. Look at the end of the brush that you would hook to the wand. In the circle opening there are two slits. On the end of the wand there are two bumps. You need to line them up, push the brush on then twist it around so it stays on. then you attach the straight wand to that and the other slightly bent wand at the other end of the straight one. It will go like this Wet hose, slightly bent wand, straight wand, slightly bent wand, and floor brush. I hope I helped. Leave the basin empty. put your water or cleaner on the floor scrub it around then turn machine on and suck it up.
Nov 30, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
