Question about Speed Computers & Internet
I need a 1980 corolla 3 speed trans rwd. Are any other trans compatible?
A-40
    Master:
  • 923 Answers
Here is a link for you ... but what you really need is called an interchange manual which will tell you what transmissions you can successfully swap for the transmission you have, covering the appropriate date range.
https://www.google.com/#q=manual+transmission+interchange+manual+1980+Toyota+Corolla
Posted on Apr 18, 2017
    New Friend:
  • 97 Answers
Which engine you got in it
Will this transmission bolt up to my van I have a 2005 astro transmission is bad. Found one with OTAD on the identification sticker. will this tansmision work?
otad doesn't help ---did the trans come out of an 05 astro van s-10 blazer /jimmy s-15 or safari and it your awd because you need to match the rwd with an rwd and a awd with an awd /4wd from above and the unit has to be compatible with the 05
Sep 22, 2016 | 2005 Chevrolet Astro
I Have a 1993 GEO Prizm that the O/D light is flashing and it starts off I 2nd or 3rd gear.. the codes that was pulled are 26 and 36.. how do I fix this problem?
1.6L or 1.8L? engine.there are 3 engines,
1.6L with one injector and one with 4 and the 1.8L with 4.
and the ecu is different on each.
tell which terminals were jumped. and which lamp flashed?
Corolla - jump DLC terminals TE1 and E1 with a short lead 1
which transaxle.?
A131, A240i, a241h, or A245e, (the e trans is tcm shifted)
The 7AFE engine has the TCM and ECU in same box.
the 1.6L single injector engine runs a pure hydraulic trans.(no TCM)
TCM's engine/trans setups.
the 4speed, has 3 ranges switches, and 3 solenoids. and speed sensors., the MPI engine ecu shifts the transmission the TBI engine does not. MPI has 4 injectors, this your car?
if the OD flashes driving, this means TCM sees errors.
can be bad sensor inputs to the TCM
or bad shifter switch, (really they are sensors too, status switches)
and the TCM can see bad speed sensors.
the TCM can also flash if the solenoids are dead. or transmission slips. (nut shell answers)
IF it skips gears, the TCM may be in limphome, they do that on errors. to protect the transmission for damage.
first, off , prizm is just a toy corolla and those are really corolla
best page on car., but i cant find your codes? are you sure you counted correclty? 26 is too rich running. (fuel ratio) 36 I can not find anywhere, (stumped me)
http://www.troublecodes.net/toyota/toyota-celica-94-95-corolla-93-95/
post vin on car and we can look up what's under the hood.
put xxxx and end of VIN. for privacy.
May 06, 2015 | Geo Cars & Trucks
Automatic Transmission on 2001 6cyl. RWD
Sounds like overdrive or the torque converter is going out. The torque converter goes into lock up then the trans goes into overdrive.
Your owners manual should have a diagram of the engine compartment showing the dipstick. Is the check engine light on ?
Jun 30, 2013 | Chevrolet Blazer Cars & Trucks
How to change settings
more shifters have two plates in it new to choice the trans you have a 3 speed or 3 speed and overdrive,being a 1980 vette,u have a350 or 400 turbo trans, e-mail the shifter manifactor to order a plate for the shifter, hope this helps
Apr 18, 2010 | 1980 Chevrolet Corvette
I need a scamatic diagram for a 3 speed auto trana
there is a program that i use on the internet that has all the info you need including tsb's and wiring diagrams. type eautorepair.com then scroll down and you will see diy. the program costs 12 dollars but has priceless info. you will find everything you need there, and if you have any trouble they have people that can help standing by. i have used them on several occasions and their diagrams are profesional quality.
May 09, 2009 | 1988 Toyota Corolla 4 Door
'95 Corolla Engine Question
An engine from another Corolla up to 1997 will fit. There are 2 engines though. 4A-fe (1.6L) or a 7A-fe (1.8L) They look similar but run different Engine managment computers. The 4A-fe uses a 3spd auto trans and the 7A-fe uses a 4spd auto trans. Also some of the wiring may be different.
Hope this helps.
Apr 30, 2009 | 1991 Toyota Corolla
Automatic Transmission problem
You didnt specify which transmission your car has,the 3 speed,model A131L,or the 4 speed A245E.Both transmissions basically have the same elements applied internally when acquiring Reverse gear.Forward clutch off,Direct clutch and Low Reverse clutch applied.The major difference between the two available transmissions for your car is,the 3 speed trans is totally hydraulic,no electronic controls,while the 4 speed trans is totally electronic control.Check the fluid level first,regardless of trans model.If your car has the 3 speed trans,it is likely an internal trans problem.Same thing for the 4 speed model,with the exception that the problem could be the electronic solenoids malfunctioning.The solenoids should be deemed defective or good,before a determination is made.
Jul 13, 2008 | 2001 Toyota Corolla
Transmission will not shift out of 1st gear
Im not sure what the code 37 definition is,as im not at work with access to code definitions,however,that trans in your truck is a variant of some type,of the A 518 model,4 speed overdrive.The year model,1994,that trans could be either a 48 RH or 48 RE.RH stands for RWD Hydraulic,and RE is RWD Electric .On the driver side of the trans,you should see a connector going straight down into the trans.If that connectror is a big,round,8 wire connector,then the trans is the RE,or Electronic model.If the connector is a small,oval,2 wire connector,then the trans is an RH or Hydraulic model.The RE/ Electric model has a governor pressure sensor and solenoid mounted on the valvebody,and are very problematic,and most times replacing with new solves the problem.When they act up,you get NO upshifts.If the trans is the RH or Hydraulic trans,then it has a mechanical governor controlling upshifts,and that would be an internal trans problem.Good luck.
Jul 08, 2008 | 1994 Dodge Ram 2500
Computers & Internet Logo
Top Speed Computers & Internet Experts
solver2010
amisset
ray gallant
Are you a Speed Computer and Internet Expert? Answer questions, earn points and help others
