Question about Bissell Vacuums
My Bissell will not sray water from the bladder, it only comes out of the solution bottle.
SOURCE: bissell carpet cleaner not spraying
I bought it brand new. I used it twice. The first use was it worked fine, the second time it wouldn't work, got it serviced for $120, now it won't work again.
You need to service it for $120 everytime you use it!
Solution-never buy anything made by Bissell again.
Just rent a steam cleaner from the supermarket when you need it, it's cheaper than owning one of these crappy lemons, and saves you storage space.
Posted on Feb 04, 2010
  • 17 Answers
SOURCE: Bissell carpet cleaner does not spray water only
Here is what to do
Posted on Feb 08, 2010
SOURCE: I have an older model Bissell rug shampoo machine,
I have a older mod. Bissell carpet machine plus mod. 1630-5 and need a floor nozzle part num.013-6194 and grip tube w/button part num.014-4181 and trigger part num.010-9406 and tube
Posted on Sep 21, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell ProHeat 2X, How do you install the Bladder
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dgjdjg
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell Proheat 2x is not dispensing the soap and
heatman101
rtfd
My bissell pro heat pet steam cleaner has mildew in the water bladder. How can I clean that?
a mixture of --napisan or bleach and cold water will kill the growth
only use cold water and rinse thoroughly after treatment
read the user manual first to make sure that bleach is acceptable to use as it may affect the bladder material
Nov 29, 2016 | Bissell Vacuums
Took inner bladder out now won't hold water
Inner bladder is needed to hold the fresh water for spray. Make sure the bladder is pulled through the bottom of the tank and that the black cap with a red rubber seal on the bottom of the tank.
If the black cap is missing you'll need to purchase a new one. Here's a quick link.
http://www.bissell.com/parts/?id=9143&sc=product&productid=2813&cid=ccsocial
Here's a quick link to locating a BISSELL Authorized Service Center if you need more assistance.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 13, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do i fill the water
There is a tank within a tank design on these deep cleaners. Use warm tap water and fill the inner bladder.
The Tank-in-Tank system is designed with a bladder inside for
clean water. As you clean, the bladder will empty. Dirty water
collects in the tank outside the bladder.
Apr 20, 2011 | Bissell 8910 ProHeat Clear View Upright...
No cleaning formula or water is coming out of the dispenser. Any suggestions.
Just a thought, did you fill the dispenser or just the bladder inside the dispenser with water? The bladder inside is filled with water through the hole on the left side of tank. The waste water then goes in the tank around the bladder, a 2 in 1 deal.
If you have filled it correctly and are still having problems, please write back.
I hope this helps. If it does, please place a vote or comment for me. Thanks,
Handie Andie
Mar 30, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have Bissell 7920. The water is not being
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
Jul 14, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Not sure where water goes ? in bladder and with solution on back
heatman101
qwewr
Apr 25, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell ProHeat Turbo 2x Carpet cleaner.
heatman101
tiutiu
Jan 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Trobble
The tank has a bladder in it, the clean water goes into the bladder, the dirty water will go on the outside of the bladder.
Feb 11, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
