Question about Sewing Machines
How do I lower the feed dog on my machine? - Sewing Machines
    Sergeant:
  • 241 Answers
Make and model would be useful
Posted on Apr 18, 2017
How do I lower the feed dogs on this machine
Joyce, Some machines do not have adjustable feed dogs. Do a Google search your make and model# manual or how to lower feed dogs. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How do raise or lower the feed dogs Brother
Tutorial Adjusting Feed Dog Height and Position ABC Sewing Machine
What Are Sewing Machine Feed Dogs and How Do they Work
Aug 23, 2016 | Sewing Machines
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
How do I lower the feed dog on a Brother LX3125?
Look on the back of the machine near the feed dogs for a lever to lower them.
If there is none then you need a feed dog cover (or darning plate) that goes over the needle plate.
good luck!
Feb 23, 2015 | Brother LX3125 Sewing Machine
How do I lower the feed dogs?
You need to say which machine you have.
Some machines use a mechanical device; some operate electrically and on some, you cannot lower the feed dogs at all.
On machines with no feed dog lowering device, the makers typically supply an additional plate that either clips over or goes under the needle plate (depending on the maker) to raise the work above the level of the feed dogs.
Dec 22, 2014 | Sewing Machines
I purchase a free motion feet but it says to do so you have to lower the feed dog does the 7422 have a button to lower the feed dog and where it is located because i could not find onew can i do free...
You don't actually have to lower your feed dogs, lots of people FMQ without lowering, or you can tap a small piece of heavy paper (like an index card) over your dogs and poke a hole in the paper for your needle to go through which effectively takes the feed dogs out of commission too.
Mar 06, 2014 | Singer 7422
Lower feed dogs
had a quick look at the manual for this at www.singer.com and I'd say your machine doesn't have the function to lower the feed dogs, many don't. It shows a darning plate which goes over the feed dogs to sew on buttons so if you are wanting to do free motion embroidery or similar, then use this plate to cover up the feed dogs.
Oct 10, 2013 | Singer 1507
Error message asking to lower feed dogs before embroidering, feed dogs were lowered
Try raising and lowering the feed dogs a couple times there may be something in there that's tripping the sensor.
Nov 11, 2012 | Janome Memory Craft 10000
How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Aug 25, 2009 | Janome Memory Craft 5700
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
