Question about Freedom Computers & Internet
Is there an e-mail address for seeking information about dla and pip under freedom of information?
Model DP52449 does it have PIP ?
No. This set has no PIP option. If you want its manual, send your email address to me, and get back a copy or it by return mail.
Jun 16, 2012 | Televison & Video
How to transfer my roadrunner emails to gmail, just purchased a iphone G4?
If you are just trying to use your RR email account on the iPhone there is really no reason to go through the hassle of setting up a G-mail account to route it through.
If you still want to use G-mail ignore the next part.
On the iPhone select the "Settings application Next select the "Mail, Contacts, Calendars" option Under the subtitle "Accounts" select the "Add Account" Option Select "Other" and under mail select "Add mail account"
Fill out the information that is required to set up an account, "Name, Address, Password, and Description) for example (Billy, Billy1@tampabay.rr.com, 123abc, Main Address)
Click Next
Scroll down to the section labelled "Incoming Mail Server"
Change the "User Name" to your e-mail address And Scroll down to the section labelled "Outgoing Mail Server"
Change the "User Name" to your email address and fill in the password as what you would use to login to the website Choose save in the top right corner of the screen and wait for the information to process, if a dialog box pops up asking you to continue without an SSL select yes and wait for you information to process once more.
This should set up your RR email account on the iPhone4
Feb 23, 2011 | Apple iPhone Smartphone
I can't get to configure my e-mail account"ojopojj@yahoo.com so that i can access it through Microsoft outlook
Per office.microsoft.com:
Add your Yahoo! Mail e-mail account
  1. On the Tools menu, click E-mail Accounts.
  2. Click Add a new e-mail account, and then click Next.
  3. Click POP3, and then click Next.
  4. Under User Information, do the following:
    1. In the Your Name box, type your full name the way that you want it to appear to other people.
    2. In the E-mail Address box, type your Member ID (or username), followed by the @ symbol and domain name.
  5. Under Server Information, do the following:
    1. In the Incoming mail server (POP3) box, type the server name from the chart below that corresponds to your e-mail address.
    2. In the Outgoing mail server (SMTP) box, type the server name from the chart below that corresponds to your e-mail address.
  6. Under Logon Information, do the following:
    1. In the User Name box, type your Yahoo Member ID (or username). Do not include the @ symbol or domain name.
    2. In the Password box, type your password.
    3. Select the Remember password check box.
 Note   You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also means that the account is vulnerable to anyone who has access to your computer. Use strong passwords that combine uppercase and lowercase letters, numbers, and symbols. Weak passwords don't mix these elements. Strong password: Y6dh!et5. Weak password: House27. Passwords should be 8 or more characters in length. A pass phrase that uses 14 or more characters is better. For more information, see Help protect your personal information with strong passwords.It is critical that you remember your password. If you forget your password, Microsoft cannot retrieve it. Store the passwords that you write down in a secure place away from the information that they help protect.
  1. To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you will be prompted to supply or correct it. Make sure your computer is connected to the Internet.
  2. Click More Settings.
  3. On the General tab, under Mail Account, type Yahoo! Mail.
  4. Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
  5. Click Use same settings as my incoming mail server, and then click OK.
  6. Click Next, and then click Finish.
 Notes
  • Do not select the Log on using Secure Password Authentication (SPA) check box.
  • Unless specified by Yahoo! Mail, all server and address entries are typed in lowercase letters.
Sep 25, 2010 | Dell Vostro 1400 Notebook
I cant get my bellsouth.net incoming mail or outgoing. had to set up my computer ater losing everything what do i put for my incoming mail server(pop, imap, http incoming mail pop, imap or...
Im assuming you are using outlook express, if not, I apologize, but steps should be similar for other types of software:
    2. In the E-mail Address box, type your e-mail user name, followed by @bellsouth.net.
    1. In the Incoming mail server (POP3) box, type mail.bellsouth.net.
    2. In the Outgoing mail server (SMTP) box, type mail.bellsouth.net.
    1. In the User Name box, type your full e-mail address, including the @bellsouth.net domain.
  1. To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you are prompted to supply or correct it. Make sure your computer is connected to the Internet.
  3. On the General tab, under Mail Account, type BellSouth.net.
  5. Select Use same settings as my incoming mail server, and then click OK.
Notes
  • Unless specified by BellSouth.net, all server and address entries are typed in lowercase letters.
Good Luck!
Aug 10, 2010 | Computers & Internet
Cannot find email server att.yahoo.com ?
In the E-mail Address box, type your e-mail user name, followed by @yahoo.com.
In the Incoming mail server (POP3) box, type pop.mail.yahoo.com.
In the Outgoing mail server (SMTP) box, type smtp.mail.yahoo.net.
In the User Name box, type your user name. Do not include @yahoo.com.
Jun 21, 2010 | Computers & Internet
I need help setting up my email on my iphone
1) If this is the first email account you're setting up on your iPhone, tap Mail. Otherwise, from the Home screen, tap Settings.
2) On the Settings screen, tap Mail.
3) On the Mail screen, under Accounts, tap Add Account.
4) On the Add Account screen, tap Other.
5) Select POP and then enter your account information using your keypad. Name Enter your name. Address Enter your email address. Description Enter a description of this email address. The description displays in your email account list on your iPhone. 6) Enter your Incoming Mail Server information.
Host Name Enter pop.secureserver.net. User Name Enter your full email address as your user name. Password Enter your password for your email account. 7) Enter your Outgoing Mail Server (SMTP) information.
Host Name Enter smtpout.secureserver.net. If you need to change your port, use one of the following for your outgoing mail server, depending on the port you want to use:
smtpout.secureserver.net:25
smtpout.secureserver.net:80
smtpout.secureserver.net:3535
User Name Enter your full email address as your user name. Password Enter your password for your email account. Note: The user name and password for your outgoing server is the same as the user name and password your entered for the incoming server.
8) If SSL mode is enabled, under Outgoing Mail Server (SMTP), tap Advanced.
9) Set Incoming Uses SSL and Outgoing Uses SSL to OFF.
Jul 16, 2009 | Apple iPhone Smartphone
I have problems to set up my account with Microsoft Office Outlook
If you are using Microsoft office outlook 2007, open your outlook, a wizard will appear, under email accounts click yes,click next, then under auto account setup, click check box on manually configure server settings then next, choose a.) internet email, (if you have your incoming and outgoing mail server), then next, then supply all information needed, account type pop3, name, email address, account name (must be the complete email address) incoming and outgoing then password, then next then hit finish or choose b.) Microsoft exchange (if you have an exchange server and you are on a network or a company) then next, fill out the information needed, your exchange server and your email address then click finish.
If you are using Microsoft office 2003, the process is just the same..
but, if you already have an existing email on your outlook and you want to modify it, go to tools, then email accounts (2003) or tools, option, mail setup, then email accounts, (2007), on the new window, double click the existing mail then supply again all the informations needed: name, email address, account name (must be the complete email address) incoming and outgoing then password. test if successful by sending an email to your own email address
Jan 31, 2009 | Yahoo Mail
Emails
The default name server due to interaction with the router?s NAT firewall feature cannot resolve simple names such as ?mail?. There is a workaround for this: First, verify that the mail client is set up with simple server names. To view the server names entered into Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". If these are simple names like "Mail" and not something like "pop.myisp.mail.com" then use this work around. Second, make sure that the TCP/IP settings are configured to obtain an IP address automatically. In Windows 2000 also make sure that the TCP/IP settings are also configured for Obtain DNS server address automatically. Replace the mail server names with the mail server IP addresses. There are a couple ways this information can be obtained. Contacting the ISP and asking is one possible way. The other way is to reconnect the original computer to the modem. Make sure the computer is restarted or that the IP configuration is released and renewed and that the computer has obtained an IP address from the ISP. Open a "COMMAND" window by typing "CMD" in the run dialog box located in the "Start" menu. At the command prompt, type "PING MAIL" where "mail" is the simple name of the incoming mail server. The ISP server will return an IP address for the mail server. Record this address. Do the same for the outgoing mail server (if different): type "PING MAIL" where "mail" is the simple name of the outgoing mail server. Open the mail client (Outlook Express, etc.). For Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". Enter the incoming and outgoing mail server IP addresses into these fields. Click "Apply". Close the window and test the mail by sending an e-mail to the mailbox. (Send an E-mail to yourself. This will test the incoming and outgoing mail all at once)
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Cant get my emails?!!!
The default name server due to interaction with the NAT firewall feature of the router cannot resolve simple names such as ?mail?. There is a workaround for this: First, verify that the mail client is set up with simple server names. To view the server names entered into Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". If these are simple names like "Mail" and not something like "pop.myisp.mail.com" then use this work around. Second, make sure that the TCP/IP settings are configured to obtain an IP address automatically. In Windows 2000 also make sure that the TCP/IP settings are also configured for Obtain DNS server address automatically. Replace the mail server names with the mail server IP addresses. There are a couple ways this information can be obtained. Contacting the ISP and asking is one possible way. The other way is to reconnect the original computer to the modem. Make sure the computer is restarted or that the IP configuration is released and renewed and that the computer has obtained an IP address from the ISP. Open a "COMMAND" window by typing "CMD" in the run dialog box located in the "Start" menu. At the command prompt, type "PING MAIL" where "mail" is the simple name of the incoming mail server. The ISP server will return an IP address for the mail server. Record this address. Do the same for the outgoing mail server (if different): type "PING MAIL" where "mail" is the simple name of the outgoing mail server. Open the mail client (Outlook Express, etc.). For Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". Enter the incoming and outgoing mail server IP addresses into these fields. Click "Apply". Close the window and test the mail by sending an e-mail to the mailbox. (Send an E-mail to yourself. This will test the incoming and outgoing mail all at once)
Feb 16, 2006 | Belkin (F5D5230-4) Router
Computers & Internet Logo
24 people viewed this question
Top Freedom Computers & Internet Experts
David Payne
David Payne
Are you a Freedom Computer and Internet Expert? Answer questions, earn points and help others
