Question about Troy-Bilt Garden
Ihave a troy-Bilt pressure washer Serial Number is 101869463 can you tell me the model number because half the part number is missing.
SOURCE: Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Posted on Apr 08, 2009
  • 76 Answers
SOURCE: Troy Bilt pressure washer model 020209 has very
you are going to need a pump seal kit or they may call it a rebuild kit but this sort of thing happens often and you should not have any trouble getting the parts you need with the kit should come a exploded view diagram but request one just to make sure be careful when putting it back together if gyou damage any of the brass or neoprene parts you will be putting it together for nothing lay out your parts on a clean towel keep all dirt and grime away and clean your pump housing really good before you put the new parts in and i mean clean enough to eat off of if you do all of these things your rebuild will probably last longer the the original good luck and get back with me if you need help with the rebuild
Posted on Jun 29, 2009
SOURCE: where do i find serial numbers on troy bilt horse tillers
On the old Gardenways Horse the serial number is stamped into the top of a little flange on the side of the transmission just to the right (viewed from behind) of where the handles attach. It may be covered in gunk so a douse of mineral spirits and a little scraping will reveal it.
You can download the manual and parts list from the Troybuilt site. Enter "HORSE" for the model and the serial number.
Posted on Aug 06, 2009
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
  • 6 Answers
SOURCE: Troy-Bilt Chipper Vac Model 47282: Need a part #
Get in touch with frederick7153@comcast.net or 651-786-4277 he has parts new and used. Also does bag repairs
Posted on Oct 29, 2009
I have a troy bilt rototiller horse, serial #7146C. Can you tell me what year it is?
Go to the Troy Built web site, find the contact phone number, call them and tell them what you want to know. Give them the serial #, and they may want to know the model also. They should be able to tell you what year it was made. Hope this helps. I will Actually see if I can find out the info for you. I will be right back. Sara I just talked to troy built, this is not the serial # this is a model number if you can check again for the complete serial# I can get you the year your tiller was made.
May 01, 2016 | Troy Garden
How do i replace the line in TB575EC trimmer?
Your manual will have diagrams and instructions in detail for restringing. You can use the following link to get it.
Both the model number and the serial number for Troy Bilt Trimmers are 11 characters in length. In your case, 41ADT41C966 is the model number, not TB575EC. You will have to find and provide the 11 character serial number. Input both of these on the following page and a manual is yours.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001&langId=-1#
May 07, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I lost mt manual to my tiller. how do i get another manual?
If you have a Troy-bilt tiller, go to http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . Enter both your model number and serial number to access the manual online. If you want to order one, the price will probably be $10.
The model and serial number are likely on a plaque on the tine housing.
I hope this helps.
Mar 22, 2011 | Troy-Bilt Garden
Need manual for Troy Bilt lawn mower 12ai867q011
Hi and welcome to FixYa. I am Kelly. You will need both your model and serial number but you can get it online directly from Troy-Bilt here:
Just enter your model and serial number and download the manual.
Thanks for choosing FixYa.
Kelly
Jul 21, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a TROY-BILT String Trimmer model TB70SS and I cannot get it restrung when the string runs out. Do you have a manual that shows how to load the string for this model?
Click Here For Your Manual.
If it takes you back to your model number & serial number, simply enter your model number and any random number for the serial. You will be able to access the manuals from there.
I hope this helps.
May 06, 2010 | Troy Bilt Tb70ss Gas Trimmer
Where do I find the model number and serial number, it is an old troy bilt rear tine tiller, two speed
The older models do not have an actual model number but only a name to distinguish the size. Early production models include the Horse, Pony and Junior. You must find the location of the serial number tag to order parts that will fit your particular rototiller for seamless replacement of parts. Hope this will help
Apr 23, 2010 | Troy-Bilt Pony Garden Tiller
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
Oct 17, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy bilt pressure washer will not build or reach high pressure
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Garden Logo
29 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
