Question about Garden
How do I remove woodruff key that has been sheared off
  • Garden Master
  • 7,063 Answers
Id suggest penetrating oil first and let it soak, then warm the shaft with a heat gun torch or blow dryer and with a smaller than the key punch try to rock it out from one end to the other with a small hammer. try not to dent the shaft of course
Posted on Apr 18, 2017
How do I replace Woodruff key in engine
Take the cover off the housing that covers the flywheel. The crank shaft comes up the middle of the flywheel and has a slot in the end. The slot has the woodruff key in it. The key fits in the slot on the flywheel. When you hit something with the blades the crankshaft stops and the flywheel keeps turning. This shears off the woodruff key or makes it move out of position and then the timing becomes out of spec. The motor wont start. You need to pull the flywheel off and replace the woodruff key. They key looks like a half moon piece of metal.
Jan 01, 2016 | Garden
I have a Yard Machines/ Briggs & Stratton 675 series 190cc lawn mower. It started this morning then stopped. I replaced the spark plug now the pull/start cord won't pull, what could be the problem.
CHECK THE OIL. If oil level gets too low, the engine may seize due to excessive friction. Check the safety interlock cable for proper operation. Check under the mower for anything that may prevent the blade from turning. If the mower hit something hard like a stump, tree root, or a large stone then check the woodruff key where the flywheel slides onto the crankshaft (there is a notch in both the flywheel and the crankshaft where this key fits). If the notches are misaligned, then the key is sheared. If the key is sheared, remove the flywheel, replace the key, reinstall the flywheel.
Apr 23, 2015 | Briggs & Stratton Garden
Why do the Yamaha MT 110V 2 stroke - engine backfire and take no load and how do I repair it
timing is fixed by way of a woodruff key on the crank that the flywheel is bolted to. only way the timing can be altered is if the woodruff key has sheared and the flywheel has spun on he crank. You would need to remove to flywheel to check if this has happened
Mar 05, 2015 | Garden
Mower stopped working
sheared the timing woodruff key if the rope jerks out of your hand replace key dealer 50.00
Sep 30, 2014 | Garden
Kawaskia atv. 400.bayou engine woodruff key sheared engine timing info.
I don't know the year of your ATV but you probably have electronic ignition. I assume the cam chain has not been disturbed. Based on that, just install a new woodruff key and go riding. The timing is pre set. Please rate my answer. Thanks.
Apr 06, 2011 | kawasaki KLX 400 R Motorcycles
Toro powerlite 98 cc 16" Mod no 38182 ser
Yes, you have a shear pin and that is probably the problem...
The shear pin often will not fall out and look like a normal piece but in fact be broken...
The shear pin usually is in the main shaft from the transmission to the auger drive...
Some are right on the auger its self...look around you will find it...
heatman101
Feb 26, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Kohler 17.5 command. will not start
The woodruff / flywheel key is likely partially sheared. Pull off the air housing, remove the starting clutch, to get to where you can see the flywheel key. I bet you will find that the key has distorted. Easily replaced once flywheel is pulled. Make sure to use the correct key when replacing it.
May 30, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Crankshaft Woodruff Key Removal
You are correct, this key does drive both. While I have never tried to remove the keway with out both pulley and lower sprocket you may be able to (my gut says no but anything is worth trying once) I'd position the keyway at the 12 o'clock postion and with a good pair of needle nose pliers see if the key will roll out as you pull up and away with it. If it will not you'll of course have to remove the front of the engine and pull the timing belt, if over 60K miles on belt go ahead and replace with new.
I hope this may have assited and good luck!
Tom
Apr 06, 2010 | 1990 Mitsubishi Montero
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
