Question about The Office Equipment & Supplies
Excess Current IB driver
The code I have is 11.100165 HFG 1: Excess Current IB Driver I also get laser not ready 80.100104
Error Code: E197 0000 in cannon 2900 printer
Printer engine communication error
Erroneous communication between the DC controller PCB and image processor PCB was detected.
- Check the connectors of the DC controller PCB and image processor PCB.
Replace the DC controller PCB for normal connection. - Replace the image processor PCB.
E197 0000 Laser Driver PCB communication error
Description :
Description Error in communication with the Laser Driver PCB (communication data failure)
Causes :
Solutions :
Remedy
1. Check the Laser Scanner Unit connector.
2. Replace the Laser Scanner Unit.
3. Replace the DC Controller PCB (PCB1).
Nov 16, 2017 | Cannon Office Equipment & Supplies
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
I got the same problem with my printer, but i got Windows XP... When I'm connecting my printer to my computer through USB a small bubble pop-up and say that the computer doesn't recognize the device. I...
Hi and welcome dark_devil_g !
Please try again .
Delete current software in Control Panel \ Programs and driver in Device manager .
Disconnect device .
Go to http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/black_white_laser_multifunction/imageclass_mf4350d#DriversAndSoftware
and make sure you download the correct driver ( Windows XP ) .
Install driver / software .
Reboot .
Connect drive and wait for confirmation hardware is ready to use .
It should work now .
Best regards ,
fanaudi .
Feb 20, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Unable to stop printing
did u check the box containing print CURRENT PAGE?????i guess u must not have done this
Oct 22, 2009 | Office Equipment & Supplies
Copier proplem
1. Reset the malfunction (i.e., turn OFF and ON the Power Switch).
or 2. If the same malfunction is still detected, check the EDH harness and, if it is okay,
change PWB-IB.
Feb 01, 2009 | Minolta DiALTA Di520 Laser Printer
Need a driver
Canon LASER SHOT LBP-1120 1.10.0.009 dlnowgrn.gif Download Now (1.43MB) Tested spyware freeinfo12.gif
Jan 04, 2009 | Canon LBP 1120 Laser Printer
E232 not recognised
Right click on the printer and make sure it is not set to work offline
Nov 01, 2008 | Lexmark E232 Laser Printer
Umax Astra 6700 download driver error code 129
here is your code mines
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER
Jul 01, 2008 | Umax Astra 6700 Flatbed Scanner
My brother MFC9420cn has error mssg " check tray #1"
Check the total page count in the menu. If it reads 288888, you have a defective engine board and it needs to be replaced. It is neither a driver issue nor a problem with the paper cartridge.
Brother will quote you a price in excess of $600 for a new engine board, but some authorized repair shops can get them for less than $200.
Oct 26, 2007 | Brother MFC-9420CN All-In-One Laser...
52 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
