Question about Filter Vacuums
I bought a used model 4232. I took it apart to clean and now I do not know how to get the filter section back into place. Also, it will not dock itself. Please, any help is welcome
  • 1673 Answers
SOURCE: won't extract water from carpet.
Seems the 1950W is now obsolete, cna't even bring up a drawing of it. Usually when the vac. motor is running, then there has to be suction. But if a seal or gaske is missing, then the suction will be lost. So you might check the dirty water tank to make sure there isn't a part missing or out of place. Check this out, it is for a 1950-3:
Posted on Jan 31, 2008
SOURCE: Rainbow
Posted by Nat51 on Jul 13, 2008
Hi: I took my unit apart to clean it. I was careful to put it back exactly as I took it apart. Now it won't start. I also need a new filter. I rinsed it out but it still stinks.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way is to check your owner’s manual to see the trouble shooting guide of which may help you. It could be a loose wire; or the separator could be on too tight, I am going to give you the Rainbow / RexAir Factory phone # so that you can check with cust serv or their serv tech support. Feel free to contact your local vacuum cleaner dealer in your area also.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below: Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 14, 2008
  • 357 Answers
SOURCE: It's been awhile since I have used my shampoo
The littlew round screen goes in the hole where the hose attaches to the tank. The round foam filter goes up in the hole underneath the on/off valve for the foam. Here is a guide if you need any more help...
Posted on Jun 28, 2009
  • 377 Answers
SOURCE: please send me a picture
Check this URL:
You should find your solution there. If not, please let me know and I will see if I can find an exploded view manual. Paul
Posted on Sep 23, 2010
  • 1739 Answers
SOURCE: I need to take the
You did not identify your model and the TriStar website does not provide manuals. They do have a FAQ page which does provide some illustrated guidance which may be helpful. See here:
If this does not assist in resolving your problem reply back with your specific model number.
Posted on Apr 10, 2011
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do i get the cover back on the vaccum cleaner
Install the long tabs in the holes and than snap i in place.
Sep 01, 2014 | Hoover Vacuums
Loss of suction
do not connect to electricity at this point claim a little work area put a blanket down as you are going to strip it all down into little bits clean and then put it all back,
Take apart power cable unwrap, unclip middle glass cylinder section to empty rubbish out, there should be a filter at the base that you can see now unclip clean put back, empty rubbish out of cylinder clean base and top rubber section and filter section with fine brush, use a wet cloth to wipe clean all black rubber suction connectors put back, at the back there will be a hose connector at the base unplug clean put back and make sure no debris is in any of the connectors and underneath where the floor brush is before you start puting it all back , Hope this helps
Feb 17, 2014 | Eureka AirSpeed Bagless Zuum
Hi, i took apart filters to clean in my dyson dc25 and put it back together as said...and now its making a highpitch whinning sound
Hi its Darran at Dyson.
It may be worth taking the filter in the ball out and putting it back making sure it has clicked back into place securely.
If you need advice on this, please visit our website at and click on the support section.
Alternatively, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Dyson Customer Service
Apr 15, 2010 | Dyson DC25 All Floors Bagless Upright...
Replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Dec 31, 2009 | Kirby Vacuums
It's been awhile since I have used my shampoo system on my Ultimate G series Kirby. Well, as instructed I took it apart and cleaned it. Now I can?t figure out where to put the ?screen cap? and ?sponge...
Jun 15, 2009 | Kirby G6 Bagged Upright Vacuum
Not picking up anything as well as it used to.
try putting new filters in, and check the hose for blockages,
Dec 23, 2008 | Eureka Capture Upright Vacuum Vacuum
Roomba Docking Station
Probably not, unless you just have to have the docking station. My roomba always had trouble mating with my docking station so I never used it. I just plugged it directly in to will using the AC adapter.
Oct 29, 2008 | Roomba Robotic Floor Bagless Vacuum
Vacuum filter
We bought one a couple years ago too, no filters. Now, WalMart carries replacement filters for other vacuums that will fit. Go back to WalMart and pick up the Durabrand CF2006 - it's in an orange box, works like a champ, I think it was around $5. We bought a couple. Great vacuum.
Aug 26, 2008 | Vacuums
Brushes still wont turn
I had same problem and it was the turbine assembly. Part was only $28 but with labor it cost me $140 total. Plus it took over 5 weeks for my vacuum repair shop to get the part. In hindsight, I would have just spent another $100-$150 dollars and bought a new cleaner because now I'm having issues with the water tank leaking and I have to replace the valve assembly. Seems like it's always something.
Jul 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
21 people viewed this question
Top Filter Vacuums Experts
Shekar Avadhani
Are you a Filter Vacuum Expert? Answer questions, earn points and help others
