Question about The Audio Players & Recorders
On a AMPD MAXXPRO MP3/MP4 PLAYER, EXPLAIN HOW TO CORRECT THE MESSAGE: Player disabled. connect to Kiosk. How do you connect to a kiosk?
early1234
  • 871 Answers
SOURCE: mp3 mp4 player
hi there
try and download this SIV (System Information Viewer) 3.28 @majorgeeks.com
this will identify whats the make of your mp3/mp4 player.
after identifying your make, post it here and we will try and find out the driver.
hope this helps.
Posted on Feb 05, 2008
keemo68
  • 1263 Answers
SOURCE: Mp3/Mp4 player not detected by the PC
there could be a glitch in the driver for the player in the computer. what i want you to do is re install the driver for the player in the computer. please post back with the result
Posted on Sep 29, 2008
SOURCE: s1 mp3 player} player of 4GB decrease to 108MB
i have brought a new mp3/mp4{s1 mp3 player} player of 4GB.when ,i made a secert space with the help of mp3 disk tool.my memory of mp3/mp4{s1 mp3 player} player
is decrease.Now it show only 108 MB.
Posted on Oct 08, 2008
SOURCE: Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Posted on Jun 20, 2009
shawty-lozzy
  • 151 Answers
SOURCE: china mp3/mp4 player hang<loading>
any more info on this? like model make e.t.c.
Posted on Jul 02, 2009
I need to connect to kiosk to auth orize my device
most devices has help number or instruction on how to work device.
Sep 01, 2013 | SanDisk Sansa E280 MP3 Player
How to get movies and videos on mp3 player
before i answer your question,i'll like to explain to you the diferent mp3 palyer with mp4 player.
Mp3 player is not Support with Videos.
Mp4 player support with Video Player.
if you using mp4 player and you want to play movie or Video in you mp4,
you'll need AMV video Converter.
you can download AMV Video Converter from HERE
If That helpfull for you,don't forget to rate me...Thanks
Dec 27, 2011 | Mach Speed Eclipse 180 MP3 Player
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
It says on the phillips site that the phillips gogear vibe mp3 player supports mp4 but everytime i add files they dont work. is there different types of mp4 files
yes your correct there are different types /size of mp4 s here is a video on Philips site that explains what sizes format are acceptable usually the player comes with a disc that has a free tool to convert videos to proper sizes hope this helps and please vote
Nov 30, 2010 | Philips GOGEAR SA6045 MP3 Player
I accidentally erased the flders that appear on the computer when i connect my mp4 how can i get the back in order for me to be able to use it again it's an MP4 Titain 4GB
hello dear jxd Ltd
here maynmar
i want to say some question about jxd mp4 player
it csreen is white screen and another jxd mp5 player is power green led is open but screen is black csreen so, pls explain me above problem
Oct 15, 2009 | Audiovox MP4128 MP3 Player
I can't get more songs than 500 mb on my 2 gb hitachi mp3/mp4
please check the connection USB mp4 to PC maybe its short... or use another USB device connect to your MP4 to PC
Jun 16, 2009 | Audio Players & Recorders
My TGE SigMatel MP4 player is giving me a message "ERROR.PLEASE REFORMAT INTERNAL MEDIA WITH SIGMATEL FORMATTER" what is the problem and how can this be fixed?
go to this webpage, http://www.tgegroup.com/en/support/download.htm I'm not sure if it will help you, you should download the correct firmware for your mp4, you can see the correct version of it turning your mp4 on and then you have to go to settings and click to the play button, it will say you the version mine is HB500(V802.551.517), so, I had to download this firmware, but... I have one problem more, my pc doesn't read my mp4, when I connect it and I open My Pc it stop my computer and I can't to see the content of my MP4, I don't know what's the problem I've tried with others computers and it doesn't works, if you can help me please do it, i would be greatful with you all my life.
Jan 20, 2009 | Sears TGE MP3 Player
Connecting to my computer
the way you connect your mp4 player to your computer is first you download the disk to your computer that came with the mp4player..then the computer will reconize the mp4 player.
Jul 18, 2008 | Delstar DS 917 Digital Media Player
CRAIG MP4 plus video player- disk error message appears.
make sure the songs you download are right for your mp4 player because Limewire only plays mp3 songs. so i would go on the internet and find a music site that has mp4 songs
Jan 28, 2008 | iLO (2 GB) MP3 Player
44 people viewed this question
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
