Question about LG Washing Machines
RE: LG front load washer. Please advise what "CL" means on the control panel and how to fix the issue.
  • 1294 Answers
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Posted on Jan 06, 2008
  • 370 Answers
SOURCE: Front Loading washer Kenmore Ht3
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
  • 4 Answers
SOURCE: lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Posted on Feb 18, 2009
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
  • 94 Answers
SOURCE: LG front load washer coded UE. what does that
UE means unbalanced error. when you see this, it means the clothes are unevenly distributed in washer, it's basically unbalanced.
Posted on Dec 03, 2009
My LG front load washer display says CL How do I fix the issue please.
Child Lock. Push and hold child lock button for 3 seconds to turn it off.
Apr 18, 2017 | LG Washing Machines
It's comes out CL letters
CL means child lock and to unlock the control press and hold the PRE WASH button for 10 seconds. Hope this helps...please post back for further assistance.
Jul 07, 2011 | LG WM2487H Front Load Washer
Can you please advise what CL means on our washing machine (LG WD1049C)
CL usually stands for child lock , look for a button indicating LOCK or child safety maybe a childs face etc. once you locate this button push for 3-6 seconds to unlock.
Jan 12, 2011 | LG WM-12230FB Front Load Washer
Hi there, my LG wd-80481tp is displaying CL, none of the buttons are working and my manual is in greek, can you advise on the problem please? thanks
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds. Please rate the solution if the issue is resolved or post a comment for further assistance.
Oct 26, 2010 | LG WD-1280FHD Front Load Washer
I have an intellowasher made by LG WD1023C I have
This means -Child Lock trying to solve the problem myself- I think by pushing 2 buttons together... but which ones?
Aug 16, 2010 | LG WD-1080FD Front Load Washer
Lg intello washer error code cl
Jan 29, 2009 | LG WM-2277HW Front Load Washer
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
Error display "CL" - what to do?
THe child lock is on. Mine came on for some random reason. On my LG front loader there is a button on the right hand side with a cartoony picture of a child and a padlock. Press this.
Jul 04, 2008 | LG WD-1280FHD Front Load Washer
Error Message CL in the front panel
Error message CL solved. CL means child lock. To deactivate press two linked buttons (on my machine the right options button and the temp button) together for a couple of seconds.
Mar 29, 2008 | LG WM-12230FB Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
